Partial or failed recordings
When recording I get partial or failed recordings. It records for the whole time it’s supposed to. The recordings are either 15 seconds to 1 minute long or it shows the correct length, but with a failed recording. I have searched without finding a solution.
I am using an iMac with 10.13.6. 2.7GHz intel core i5. I have over 400GB of storage available. Plex Media Server Logs_2018-08-31_11-53-43.zip (5.7 MB)
HDHomeRun Connect.
I have the zip file of logs. I can’t figure out how to read them.
Thank you.
Everything is now connect to CAT5e. Still the same problem.
Has this never happened to anyone?
Any suggestions from the Plex staff?
Ok, so I am away home a lot but finally figured it out. I turned off remove commercials and it fixed the problem. I now get full recordings. Now the question is, “Why all of a sudden is this a problem?”
