Thank you. I tried initially to run after your reply, but didn’t enable emails so the results never came to me. Then work got in the way. Below are the results:
Task: Task 3
Start time: Sat, 22 Jan 2022 21:14:16 GMT
Stop time: Sat, 22 Jan 2022 21:14:17 GMT
Current status: 0 (Normal)
Standard output/error:
Error: /dev/md2: unrecognised disk label
Error: /dev/mtdblock0: unrecognised disk label
Error: /dev/mtdblock1: unrecognised disk label
Error: /dev/mtdblock2: unrecognised disk label
Error: /dev/mtdblock3: unrecognised disk label
Error: /dev/mtdblock4: unrecognised disk label
Model: WDC WD60EZRX-11MVLB1 (scsi)
Disk /dev/hda: 6001GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 2551MB 2550MB ext4 raid
2 2551MB 4699MB 2147MB linux-swap(v1) raid
5 4840MB 6001GB 5996GB raid
Disk /dev/sda: 6001GB
Disk Flags:
Model: ATA ST6000VN001-2BB1 (scsi)
Disk /dev/sdb: 6001GB
Disk Flags:
Model: Linux Software RAID Array (md)
Disk /dev/md0: 2550MB
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 2550MB 2550MB ext4
Disk /dev/md1: 2147MB
Disk Flags:
1 0.00B 2147MB 2147MB linux-swap(v1)
Disk /dev/md2: 5996GB
Partition Table: unknown
Disk Flags:
Model: Unknown (unknown)
Disk /dev/mtdblock0: 1049kB
Disk Flags:
Disk /dev/mtdblock1: 3080kB
Disk Flags:
Disk /dev/mtdblock2: 4190kB
Disk Flags:
Disk /dev/mtdblock3: 65.5kB
Disk Flags:
Disk /dev/mtdblock4: 4096B
Disk Flags:
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/md0 2385528 1024108 1242636 46% /
none 310612 0 310612 0% /dev
/tmp 329196 2064 327132 1% /tmp
/run 329196 13324 315872 5% /run
/dev/shm 329196 8 329188 1% /dev/shm
none 4 0 4 0% /sys/fs/cgroup
/dev/vg1000/lv 5809359680 5433647544 375593352 94% /volume1
