Path for live TV recording without setting each show
I have two directories on my computer that are shared in a library called TV Shows:
\Saved TV Shows\ -> This is where I put complete series and seasons that I keep forever. It is backed up to the cloud.
\Recorded TV shows\ -> This is where I put shows that I record, watch, and delete. It is not backed up elsewhere.
So every single time I hit record on a show, where does it go? I don’t want to edit every single recording over and over and over again. I just want it to ALWAYS record ANY show to a specific path. All I’ve found so far is to click record, and then go to the computer, and edit the recording manually to set a path. Is there any other way?
There is a box that you can specify where the records get saved. It should default to the last folder you chose.
Which client are you doing this from? It might be a bug in the client missing the option to choose the location.
That’s it exactly. I didn’t realize there is an option to choose the location. I’ll just set shows to record using the app or web interface from here on out.
