Separate DVR Recording Location?
For recording my DVR TV Shows, I’d like to set a drive different than my Movie drive volume.
Where are the files saved while recording is happening? Are the live recordings stored in the “TV Shows” folder or are they moved there after a recording is completed?
While recording, is uses two locations. The temp transcoder directory and .grab in the location where you specified the TV Library. When the recording is complete the file is moved from .grab to the final location and the transcoder directory is flushed.
