Hi all
Using latest plexconnect on atv3.
While using letmewatchthis.
I’m not having buffering or loading issues,
There can be plenty of content loaded according to the bar on atv3 just that quite often it pauses then gets audio out of sync, I then have to rewind slightly and run again to correct this.
If Anyone could help me with this would be much appreciated.
I’m at work now so sorry I couldn’t give you more info on things
Cheers
Riche.
Bump
We’ll if it pauses then it’s either buffering or you are accidentally pressing a button on your remote to pause I would imagine. Do you see a spinning wheel or do you see it pause when the issue occurs.
Ok I should have said it freezes for a short period , there’s no spinning wheel , and too me it looks like there’s plenty of content already loaded while this occurs.
The video just stops? Can you post a screen shot when it occurs? I imagine this a Chanel issue. When I experience these issues it’s when it buffers or when I use ssplex or lmwt but it buffers for me and a see a small spinning wheel at the loading bar when the audio loses sync.
