Pb transcoding no fluid.
Hello I have a HP micro server N40L with plex server is very very hard to read the 1080p ethernet apple TV3 with transcoding.
my question, is it more fluid if I install plex connect into the apple tv3 or same?
Thant you for response and sorry for my bad english…(French guy)
It is hard to understand what the problem is.
Can you ask your question again in French and hopefully another member will be able to translate it:)
I guess he wants to ask if the combination consisting of the N40L micro server and PlexConnect and AppleTV3 will work. The answer is no, the N40L does not have enough power to transcode 1080p or 720p
I would say it depends.. If the files are in an Apple friendlt format it should be possible, as no transcoding is needed. (I have the same setup)
In that case subler/iFlicks or similar may be needed to remux non-compatible formats.
There is no jailbreak for aTV3 available - no chance currently to install Plex-anything on it.
Ok i can change my N40l…
I’ll take a mini mac I think.
thank you very much for your quick help and interest.
