I’ve used Plex in the past and now that I got a server running at home I decided to make a try.
So I donwloaded the installer (linux 64 bit) as I’m running Ubuntu 18.04 x64 from here: https://www.plex.tv/media-server-downloads/#plex-media-server.
I sign-in from a computer on the same network to the web interface (server.ip:32400) and I don’t get any “setup server” configuration. It keeps “looking for servers…” on the left top navbar, I also don’t find any server related configuration settings.
First I followed this guide https://support.plex.tv/articles/115007577087-devices/ with no success. I don’t get listed any servers.
Then I though it could be because I’m not making the request from the same host so I tried to setup an apache proxy, results in the same behabiour.
Tried purging the software, removing installer and downloading again. Allways the same behabiour (also cleared browser cache).
The process is running correctly, doesn’t show any errors
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2019-05-24 22:58:29 CEST; 32min ago
Process: 17392 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -
Main PID: 17398 (sh)
Tasks: 67 (limit: 4915)
CGroup: /system.slice/plexmediaserver.service
├─17398 /bin/sh -c PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{print \$2}" | tr
├─17414 /usr/lib/plexmediaserver/Plex Media Server
├─17435 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-78232c603/Framework.bun
├─17491 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib
└─17497 /usr/lib/plexmediaserver/Plex DLNA Server
May 24 22:58:29 sysnameremoved systemd[1]: Starting Plex Media Server...
May 24 22:58:29 sysnameremoved systemd[1]: Started Plex Media Server.
Are they on the same subnet?
Is the subnet RFC-1918 compliant (192.168.x.x, 10.x.x.x, or 172.16.x.x -> 172.31.x.x ) ?
DNS and gateway on that host valid?
This all in order,
Terminal window
elevate to root shell
Stop PMS
Rename “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Preferences.xml” to “Preferences.xml-prev”
I’m accesing the server from the IP. I previously tried accesing it through an apache proxy, but it didn’t suceed anyway.
I’m uploading the crash reports folder crashes.tar.gz (234 Bytes)
Edit:
I’ve installed the plex media server on my windows 10 machine and It got recogniced perfecly on the Plex instance installed on the server.
I don’t know why, but I tried a last time accesing the Plex instance of the server but instead of using the FQDN an IP address and it appeared the server configuration wizard.
So now my question is: why wasn’t previously appearing the wizard? I was accessing the same site but instead of using the direct IP address I was using a domain name. It also didn’t work through a proxy.
