Server Version#: 1.23.5.4841
Player Version#: 8.20.0.26605 (781d3db5)
I’ve seen similar topics on the forum, but none with a workable solution.
Burning subtitles and transcoding server-side isn’t an option unfortunately…
I have an Nvidia Shield Pro 2019 running the client and a MacMini running the server, Plex versions above.
Trying to play a 4k HDR file with DTS-HD MA audio tracks and PGS subtitles.
Dashboard reports Direct Play on all streams, but the Shield won’t display the subtitles. No errors or crashes. Just no subtitles.
I’ve tried disabling HDMI audio passthrough, as some folks had mentioned this as a possible solution. Made no difference in this case…
The file is known good. MRMC plays it perfectly from the Plex server, so it seems to be an issue with the Plex client?
Anything else I can try?
Thanks.
