Server Version#: Version 1.24.5.5173
How can I get Plex Media Server to display PGS subtitles from the MKV ?
The machine where the Plex server is installed has Geforce GTX 1650 video card, and I have Plex Pass.
So, the hardware transcoding works.
Yet, it does not show me the PGS subtitles
Burning in subtitles is not reliant on hardware transcoding. It uses 100% software, so the main CPU needs to be fast enough.
Are you certain that the PGS subtitle has been ripped correctly?
Is it visible in a regular desktop video player like MPC-HC or VLC?
Yes, the subtitles are visible in MPC-HC
(PS: PGS are only being ātreatedā in software? I didnāt know that)
The Plex server is installed on a HP Z620 machine, with 96GB DDR3 Quad channel and 2 * Xeon E2667 v2 3.3GHz with 4 GHz Turbo frequency
This CPU might be enough for transcoding/burning-in subs in 1080p, but not 4K material.
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Xeon+E5-2667+v2+%40+3.30GHz&id=2154
Please post the first ~20 lines from the Plex XML info of an affected video.
The movies I was asking about was 1080p but it was encoded with H.256
Could the codec I used be the problem ?
It should not be a problem, if your hardware transcoding works correctly.
Is it using 10-bit color/HDR?
No it is not HDR.
It is only SDR.
I only transcoded it to H.265 in order to save some HDD space
It is 8 bit H.265
If you convert the PGS subtitles to SRT, everything works as expected?
I didnāt try to convert those PGS to SRT, but STRs do work perfectly.
I did find a SRT subtitle for this movie and it works perfectly
Ok, thanks for confirming!
Could you
Plex Media Server Logs_2021-11-16_18-36-49.zip (5.3 MB)
I want to tell you that before the restart the PGS subtitles were not even visible in PLEX.
After restart they became visible and everything works.
However, please do have a look in the logs.
Maybe you will find the problem for this issue
Thanks a lot
With ānot visibleā, do you actually mean
The PGS subtitle was not being shown in the subtitle selection zone
I did not have any subtitle available to select
Nothing was shown
Internal subtitles: Analyze Analyze Media | Plex Support
External subtitles: Refresh Metadata Scanning vs Refreshing a Library | Plex Support
OK, Thank you.
I have this problem too on plex client for Firestick 4K. PGS titles simply will not display from an MKV file. I can select them, but nothing comes up. The PGS titles work on Plex client for Windows on my PC though. Iām running latest Plex server on windows 7.
