Original Post: https://forums.plex.tv/topic/131166-qnap-269l-plex-connect-atv3-pic-freezing-with-subs/
Was advised to post this here.
I am currently experiencing picture freeze when I view content with subtitles. Everything would work perfectly if subs would be turned off.
I am currently using server Version 0.9.11.4 on an Apple TV3 with a Qnap 269L
thanks for your help in advanced.
drewbie
December 10, 2014, 6:45am
2
It sounds like the CPU in the QNAP is not powerful enough to transcode. What’s the performance of the NAS like when you have this issue?
It sounds like the CPU in the QNAP is not powerful enough to transcode. What's the performance of the NAS like when you have this issue?
I could see this being the problem.
Try going into the settings on your PlexConnect and switching the Playback from "Play" to "DirectPlay W/Fallback".
Could solve the problem.
-AJ
According to this list it's clearly a problem of low CPU power for transcoding. If the subs are SRT external you may opt to use the PlexConnect subtitle renderer mechanism instead.
