How do you get the PINNED dashboard view to be the default so it comes up every time server is opened in a browser? HOME dashboard seems to be the only thing that can be default and it no longer has all the features I been using for the past two years. But PINNED does have them, but is a hassle to get to.
there is not a way to default to the server listings when you click on MORE if that is what you mean
When you start the version of Plex that runs in a browser window and just shows the folders that have been added to plex (which I assume is the SERVER?) the default left side listing is NOW showing HOME at the top. If you go to the bottom of that left column there is a MORE option (in my case it a LONG ways down) that, when clicked changes the label at the top from HOME to the name of the server. Then, and only then, can you click the + sign and add libraries or folders. Used to be able to do this without all the running around, can the server name be set as the default rather than it being HOME? That was the question.
The side bar can have libraries from multiple servers. basically it is used like favorites. if you have libraries from multiple servers that are yours, the server name will show below it. mediabox and QNAPserver are two of my servers in image below showing under the libraries names. (qnap is disconnected at the moment) I have many more libraries than that on those servers but 99% of the time only care about those.
The “home” screen is for the common hubs most folks use which can also be from multiple servers and libraries. If you want to see Recently Added TV from Server X and Recently Added Movies from Server Y for example. I don’t pin one of my friends server libraries on the side bar but I do add the On Deck hub to home from his server because I only watch one show he has and only care when a new episode of that is available.
