Play spinning with Synology, "EAE timeout! EAE not running, or wrong folder? Could not read"
Server Version#: 1.21.1.3876-3c3adfcb4
Player Version#: varies
Ever since I updated from 1.21.1.3830-6c22540d5 to this latest build, I have been getting the spinning wheel on some media. Seems to be certain media files with EAC3 audio coding but not all files/shows with EAC3.
See logs;
Logs are two different files
Jan 21, 2021 07:19:15.209 [0x7efdf59e9700] Warning — [Transcode] Got a transcode session ping without a session GUID (or with an invalid one).
Jan 21, 2021 07:19:17.000 [0x7efdf59e9700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-0.wav'
Jan 21, 2021 07:19:17.001 [0x7efdf59e9700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:17.002 [0x7efdf59e9700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:20.000 [0x7efdf59e9700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-1.wav'
Jan 21, 2021 07:19:20.001 [0x7efdf59e9700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:20.001 [0x7efdf59e9700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:23.000 [0x7efdf59e9700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-2.wav'
Jan 21, 2021 07:19:23.001 [0x7efdf59e9700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:23.001 [0x7efdf59e9700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:26.000 [0x7efdfc855700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-3.wav'
Jan 21, 2021 07:19:26.003 [0x7efdfc855700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:26.006 [0x7efdfc855700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:29.001 [0x7efdfffff700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-4.wav'
Jan 21, 2021 07:19:29.002 [0x7efdfffff700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:29.002 [0x7efdfffff700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:32.000 [0x7efdfffff700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-5.wav'
Jan 21, 2021 07:19:32.003 [0x7efdfffff700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:32.003 [0x7efdfffff700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:35.000 [0x7efdfffff700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-6.wav'
Jan 21, 2021 07:19:35.002 [0x7efdfffff700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:35.004 [0x7efdfffff700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:38.000 [0x7efdf4e31700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-7.wav'
Jan 21, 2021 07:19:38.003 [0x7efdf4e31700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:38.003 [0x7efdf4e31700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:41.000 [0x7efdf4b43700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-8.wav'
Jan 21, 2021 07:19:41.001 [0x7efdf4b43700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:41.003 [0x7efdf4b43700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:44.000 [0x7efdf4b43700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-9.wav'
Jan 21, 2021 07:19:44.001 [0x7efdf4b43700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:44.001 [0x7efdf4b43700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:45.207 [0x7efdf4b43700] Warning — [Transcode] Got a transcode session ping without a session GUID (or with an invalid one).
Jan 21, 2021 07:19:47.000 [0x7efdf4b43700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-10.wav'
Jan 21, 2021 07:19:47.001 [0x7efdf4b43700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:47.001 [0x7efdf4b43700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:50.000 [0x7efdf4855700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-11.wav'
Jan 21, 2021 07:19:50.002 [0x7efdf4855700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:50.003 [0x7efdf4855700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:53.000 [0x7efdb7fff700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-12.wav'
Jan 21, 2021 07:19:53.002 [0x7efdb7fff700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:53.003 [0x7efdb7fff700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:56.000 [0x7efdb7d11700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-13.wav'
Jan 21, 2021 07:19:56.003 [0x7efdb7d11700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:56.003 [0x7efdb7d11700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:19:59.000 [0x7efdb7d11700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-14.wav'
Jan 21, 2021 07:19:59.001 [0x7efdb7d11700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:19:59.001 [0x7efdb7d11700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:20:02.000 [0x7efdb7d11700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-15.wav'
Jan 21, 2021 07:20:02.002 [0x7efdb7d11700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:20:02.004 [0x7efdb7d11700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:20:05.000 [0x7efdb7d11700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-16.wav'
Jan 21, 2021 07:20:05.000 [0x7efdb7d11700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:20:05.001 [0x7efdb7d11700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:20:08.000 [0x7efdb7a23700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-17.wav'
Jan 21, 2021 07:20:08.001 [0x7efdb7a23700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:20:08.001 [0x7efdb7a23700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:20:11.000 [0x7efdb7735700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-18.wav'
Jan 21, 2021 07:20:11.002 [0x7efdb7735700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:20:11.004 [0x7efdb7735700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:20:14.000 [0x7efdb6e6b700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-19.wav'
Jan 21, 2021 07:20:14.001 [0x7efdb6e6b700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:20:14.001 [0x7efdb6e6b700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:20:15.204 [0x7efdb6e6b700] Warning — [Transcode] Got a transcode session ping without a session GUID (or with an invalid one).
Jan 21, 2021 07:20:17.000 [0x7efdb6e6b700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-20.wav'
Jan 21, 2021 07:20:17.001 [0x7efdb6e6b700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:20:17.001 [0x7efdb6e6b700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:20:20.000 [0x7efdb65a1700] Error — [Transcoder] [eac3_eae @ 0x23c7440] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mjycj7k75lrmr7kdziby3jc9_29984-0-21.wav'
Jan 21, 2021 07:20:20.002 [0x7efdb62b3700] Error — [Transcoder] [eac3_eae @ 0x23c7440] error reading output
Jan 21, 2021 07:20:20.002 [0x7efdb6e6b700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:20:22.035 [0x7efdf540d700] Warning — [Transcode/mjycj7k75lrmr7kdziby3jc9] Transcode runner appears to have died.
Jan 21, 2021 07:20:22.036 [0x7efdb7447700] Warning — [Transcode/mjycj7k75lrmr7kdziby3jc9] Transcode runner appears to have died.
Jan 21, 2021 07:20:22.038 [0x7efdb7159700] Warning — [Transcode/mjycj7k75lrmr7kdziby3jc9] Transcode runner appears to have died.
Jan 21, 2021 07:20:22.040 [0x7efdf59e9700] Warning — [Transcode/mjycj7k75lrmr7kdziby3jc9] Transcode runner appears to have died.
Jan 21, 2021 07:20:22.043 [0x7efdf65a1700] Warning — [Transcode/mjycj7k75lrmr7kdziby3jc9] Transcode runner appears to have died.
Jan 21, 2021 07:20:22.074 [0x7efdf5fc5700] Warning — [Transcode/mjycj7k75lrmr7kdziby3jc9] Transcode runner appears to have died.
Jan 21, 2021 07:20:22.080 [0x7efdb7735700] Warning — [Transcode/mjycj7k75lrmr7kdziby3jc9] Transcode runner appears to have died.
Jan 21, 2021 07:20:22.081 [0x7efdf4567700] Warning — [Transcode/mjycj7k75lrmr7kdziby3jc9] Transcode runner appears to have died.
Jan 21, 2021 07:20:22.096 [0x7efdf4855700] Warning — [Transcode/mjycj7k75lrmr7kdziby3jc9] Transcode runner appears to have died.
Jan 21, 2021 07:20:22.097 [0x7efdf511f700] Warning — [Transcode/mjycj7k75lrmr7kdziby3jc9] Transcode runner appears to have died.
Jan 21, 2021 07:20:22.100 [0x7efdf4e31700] Warning — [Transcode/mjycj7k75lrmr7kdziby3jc9] Transcode runner appears to have died.
Jan 21, 2021 07:20:25.000 [0x7efdf511f700] Error — [Transcoder] [eac3_eae @ 0x151c140] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/otyuofjtwdf17a28zmbt1cre_30608-0-0.wav'
Jan 21, 2021 07:20:25.001 [0x7efdf540d700] Error — [Transcoder] [eac3_eae @ 0x151c140] error reading output
Jan 21, 2021 07:20:25.001 [0x7efdb7447700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 21, 2021 07:20:28.000 [0x7efdf59e9700] Error — [Transcoder] [eac3_eae @ 0x151c140] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-4fc2ce9f-4801-4d37-9c7e-8bb2290ea59a/EasyAudioEncoder/Convert to WAV (to 8ch or less)/otyuofjtwdf17a28zmbt1cre_30608-0-1.wav'
Jan 21, 2021 07:20:28.002 [0x7efdf65a1700] Error — [Transcoder] [eac3_eae @ 0x151c140] error reading output
Jan 21, 2021 07:20:28.003 [0x7efdf4567700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
MODERATOR EDIT: Added code formatting for legibility
May we have the full logs ZIP file which captures this (DEBUG logging on, VERBOSE logging off) ?
It is impossible to diagnose this type of snippet.
It would be most beneficial if you can restart Plex,
give it 2 minutes to stabilize after the restart,
then recreate the issue.
This lets us see the startup sequence as well.
Plex Media Server Logs_2021-01-21_10-36-57.zip (3.1 MB)
Logs uploaded. 10:31 or 32 it was rebooted. Attempted to load two different files and let them run for a few moments. Thank you for your help.
Confirmed: You’re running out of notify slots.
Jan 21, 2021 10:32:19.567 [0x7fbcd7735700] DEBUG - [Notify] Now watching "/volume1/Video/TV Shows/The Pacific (2010)/The Pacific - Season 01/The.Pacific.2010.EP02.1080p.AC3.DTS.x264.Eng.NLSubs-DMT"
Jan 21, 2021 10:32:19.567 [0x7fbcd7735700] DEBUG - [Notify] Now watching "/volume1/Video/TV Shows/The Pacific (2010)/The Pacific - Season 01/The.Pacific.2010.EP03.1080p.AC3.DTS.x264.Eng.NLSubs-DMT"
Jan 21, 2021 10:32:19.567 [0x7fbcd7735700] DEBUG - [Notify] Now watching "/volume1/Video/TV Shows/The Pacific (2010)/The Pacific - Season 01/The.Pacific.2010.EP04.1080p.AC3.DTS.x264.Eng.NLSubs-DMT"
Jan 21, 2021 10:32:19.567 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The Pacific (2010)/The Pacific - Season 01/The.Pacific.2010.EP05.1080p.AC3.DTS.x264.Eng.NLSubs-DMT" (28: No space left on device)
Jan 21, 2021 10:32:19.567 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The Pacific (2010)/The Pacific - Season 01/The.Pacific.2010.EP06.1080p.AC3.DTS.x264.Eng.NLSubs-DMT" (28: No space left on device)
Jan 21, 2021 10:32:19.568 [0x7fbcd59e9700] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 21, 2021 10:32:19.568 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The Pacific (2010)/The Pacific - Season 01/The.Pacific.2010.EP07.1080p.AC3.DTS.x264.Eng.NLSubs-DMT" (28: No space left on device)
Jan 21, 2021 10:32:19.568 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The Pacific (2010)/The Pacific - Season 01/The.Pacific.2010.EP08.1080p.AC3.DTS.x264.Eng.NLSubs-DMT" (28: No space left on device)
Jan 21, 2021 10:32:19.568 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The Pacific (2010)/The Pacific - Season 01/The.Pacific.2010.EP09.1080p.AC3.DTS.x264.Eng.NLSubs-DMT" (28: No space left on device)
Jan 21, 2021 10:32:19.568 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The Pacific (2010)/The Pacific - Season 01/The.Pacific.2010.EP10.1080p.AC3.DTS.x264.Eng.NLSubs-DMT" (28: No space left on device)
Jan 21, 2021 10:32:19.568 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST" (28: No space left on device)
Jan 21, 2021 10:32:19.568 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/English Subs (SRT)" (28: No space left on device)
Jan 21, 2021 10:32:19.568 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/English Subs (SRT)/Season 1" (28: No space left on device)
Jan 21, 2021 10:32:19.568 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/English Subs (SRT)/Season 2" (28: No space left on device)
Jan 21, 2021 10:32:19.569 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/English Subs (SRT)/Season 3" (28: No space left on device)
Jan 21, 2021 10:32:19.569 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/English Subs (SRT)/Season 4" (28: No space left on device)
Jan 21, 2021 10:32:19.570 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/English Subs (SRT)/Season 5" (28: No space left on device)
Jan 21, 2021 10:32:19.570 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/English Subs (SRT)/Season 6" (28: No space left on device)
Jan 21, 2021 10:32:19.570 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/LOST - Season 01" (28: No space left on device)
Jan 21, 2021 10:32:19.570 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/LOST - Season 02" (28: No space left on device)
Jan 21, 2021 10:32:19.571 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/LOST - Season 03" (28: No space left on device)
Jan 21, 2021 10:32:19.571 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/LOST - Season 04" (28: No space left on device)
Jan 21, 2021 10:32:19.571 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/LOST - Season 05" (28: No space left on device)
Jan 21, 2021 10:32:19.572 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/LOST/LOST - Season 06" (28: No space left on device)
Jan 21, 2021 10:32:19.572 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/Life (2007)" (28: No space left on device)
Jan 21, 2021 10:32:19.572 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/Life (2007)/Life - Season 01" (28: No space left on device)
Jan 21, 2021 10:32:19.572 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/Life (2007)/Life - Season 02" (28: No space left on device)
Jan 21, 2021 10:32:19.572 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)" (28: No space left on device)
Jan 21, 2021 10:32:19.572 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)/The 100 - Season 07" (28: No space left on device)
Jan 21, 2021 10:32:19.572 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)/The 100 - Season 07/The.100.S07E13.1080p.CW.WEBRip.AAC2.0.H264-BTN[rarbg]" (28: N
Part of the problem here is that you’re keeping a lot of extra directories which you really do not need.
As example:
Jan 21, 2021 10:32:19.573 [0x7fbcd6b7d700] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jan 21, 2021 10:32:19.573 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)/The 100 - Season 07/The.100.S07E11.1080p.WEB.H264-BTX[rarbg]" (28: No space left on device)
Jan 21, 2021 10:32:19.574 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)/The 100 - Season 07/The.100.S07E12.1080p.WEB.H264-OATH[rarbg]" (28: No space left on device)
Jan 21, 2021 10:32:19.574 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)/The 100 - Season 07/The.100.S07E01.1080p.WEB.H264-ALiGN[rarbg]" (28: No space left on device)
Jan 21, 2021 10:32:19.574 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)/The 100 - Season 07/The.100.S07E02.1080p.WEB.H264-BTX[rarbg]" (28: No space left on device)
Jan 21, 2021 10:32:19.574 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)/The 100 - Season 07/The.100.S07E03.1080p.WEB.H264-BTX[rarbg]" (28: No space left on device)
Jan 21, 2021 10:32:19.574 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)/The 100 - Season 07/The.100.S07E04.1080p.HDTV.x264-CRAVERS[rarbg]" (28: No space left on device)
Jan 21, 2021 10:32:19.574 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)/The 100 - Season 07/The.100.S07E14.1080p.WEB.h264-BAE[rarbg]" (28: No space left on device)
Jan 21, 2021 10:32:19.574 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)/The 100 - Season 07/The.100.S07E15.1080p.WEB.H264-VIDEOHOLE[rarbg]" (28: No space left on device)
Jan 21, 2021 10:32:19.574 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)/The 100 - Season 07/The.100.S07E16.1080p.WEB.H264-CAKES[rarbg]" (28: No space left on device)
Jan 21, 2021 10:32:19.575 [0x7fbcd7735700] ERROR - [Notify] Failed to add watch for "/volume1/Video/TV Shows/The 100 (2014)/The 100 - Season 03" (28: No space left on device)
These should all be simple files in the Season 7 folder. They should not be directories. You’re wasting a slot for each episode for nothing.
If you have as single files, when the file gets changed, the “Season 07” folder will catch the change as it should and PMS will be notified.
As first step to remedy this, I recommend getting a renaming tool, such as FileBot or TheRenamer and cleaning up the directory structure. It will give you proper Series/Season xx/episode structure without the extra waste.
Then, after cleaning it up, if you still run out of slots, we can increase the number of folders to watch at the DSM level.
Also:
Subtitles don’t go in subdirectories, they are placed adjacent the file.
Jan 21, 2021 10:32:19.567 [0x7fbcd7735700] DEBUG - [Notify] Now watching "/volume1/Video/TV Shows/The Pacific (2010)/The Pacific - Season 01/The.Pacific.2010.EP01.1080p.AC3.DTS.x264.Eng.NLSubs-DMT"
Additionally, this naming is not per naming rules:
Series - SxxExx - Optional Title here [optional hidden extras here].ext
I have cleaned up at least what you had listed plus some other folders that I could think of. Still running into the same issue. I will keep cleaning the folder structure to improve things but dont think this has solved the issue yet. Server has also been rebooted and library scan ran.
EDIT
Cleaned up more of the file structure and after another reboot, rescan and database optimization, things are playing correctly again. Thanks for the help
You might want to configure your media acquisition settings to not make subdirectories for each episode. It’ll help prevent this from recurring prematurely
@dubiemon
An afterthought:
A lot of us have FileBot or TheRenamer to perform mass renaming / restructuring tasks.
Personally, I use FileBot. It will clean things up in a heartbeat.
If you’re interested, I’ll give you my renaming rules so you can tailor to suit your environment.
