Hallo Fories, Habe einen Plex Server im Synology Docker laufen und habe täglich immer wieder 100% Auslastung der CPU durch nen für mich nicht identifizierbaren / stoppbaren Prozess.
Ich hoffe es kann jemand helfen.
In der Konsole steht dann immer:
Jun 04, 2024 07:18:18.001 [140365017049912] ERROR - [Req#babff/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] [eac3_eae @ 0x7f90b0209080] error reading output: -5 (I/O error)
Jun 04, 2024 07:18:18.001 [140365121252152] ERROR - [Req#bac00/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] Error while decoding stream #0:1: I/O error
Jun 04, 2024 07:18:23.000 [140365017049912] ERROR - [Req#bac01/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] [eac3_eae @ 0x7f90b0209080] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-fac3da09-ff8b-4c81-b265-f1b4d7b5a2ff/EasyAudioEncoder/Convert to WAV (to 8ch or less)/13cc009d-3b87-4dae-b88f-48392c943ccf_32161-0-349.wav'
Jun 04, 2024 07:18:23.001 [140365121252152] ERROR - [Req#bac02/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] [eac3_eae @ 0x7f90b0209080] error reading output: -5 (I/O error)
Jun 04, 2024 07:18:23.001 [140365070809912] ERROR - [Req#bac03/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] Error while decoding stream #0:1: I/O error
Jun 04, 2024 07:18:28.000 [140365017049912] ERROR - [Req#bac04/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] [eac3_eae @ 0x7f90b0209080] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-fac3da09-ff8b-4c81-b265-f1b4d7b5a2ff/EasyAudioEncoder/Convert to WAV (to 8ch or less)/13cc009d-3b87-4dae-b88f-48392c943ccf_32161-0-350.wav'
Jun 04, 2024 07:18:28.001 [140365121252152] ERROR - [Req#bac05/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] [eac3_eae @ 0x7f90b0209080] error reading output: -5 (I/O error)
Jun 04, 2024 07:18:28.001 [140365070809912] ERROR - [Req#bac06/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] Error while decoding stream #0:1: I/O error
Jun 04, 2024 07:18:33.000 [140365017049912] ERROR - [Req#bac07/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] [eac3_eae @ 0x7f90b0209080] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-fac3da09-ff8b-4c81-b265-f1b4d7b5a2ff/EasyAudioEncoder/Convert to WAV (to 8ch or less)/13cc009d-3b87-4dae-b88f-48392c943ccf_32161-0-351.wav'
Jun 04, 2024 07:18:33.001 [140365121252152] ERROR - [Req#bac08/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] [eac3_eae @ 0x7f90b0209080] error reading output: -5 (I/O error)
Jun 04, 2024 07:18:33.001 [140365070809912] ERROR - [Req#bac09/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] Error while decoding stream #0:1: I/O error
Jun 04, 2024 07:18:38.000 [140365017049912] ERROR - [Req#bac0a/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] [eac3_eae @ 0x7f90b0209080] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-fac3da09-ff8b-4c81-b265-f1b4d7b5a2ff/EasyAudioEncoder/Convert to WAV (to 8ch or less)/13cc009d-3b87-4dae-b88f-48392c943ccf_32161-0-352.wav'
Jun 04, 2024 07:18:38.001 [140365070809912] ERROR - [Req#bac58/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] [eac3_eae @ 0x7f90b0209080] error reading output: -5 (I/O error)
Jun 04, 2024 07:18:38.001 [140365121252152] ERROR - [Req#bac59/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] Error while decoding stream #0:1: I/O error
Jun 04, 2024 07:18:43.000 [140365070809912] ERROR - [Req#bac5a/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] [eac3_eae @ 0x7f90b0209080] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-fac3da09-ff8b-4c81-b265-f1b4d7b5a2ff/EasyAudioEncoder/Convert to WAV (to 8ch or less)/13cc009d-3b87-4dae-b88f-48392c943ccf_32161-0-353.wav'
Jun 04, 2024 07:18:43.001 [140365121252152] ERROR - [Req#bac5d/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] [eac3_eae @ 0x7f90b0209080] error reading output: -5 (I/O error)
Jun 04, 2024 07:18:43.001 [140365017049912] ERROR - [Req#bac5e/Transcode/13cc009d-3b87-4dae-b88f-48392c943ccf/5d237510-ed6e-42ac-830b-15806cb17f2d] Error while decoding stream #0:1: I/O error
Das ganze endlos…
Was kann ich machen um dies zu verhindern, zu fixen, oder dauerhaft zu stoppen ?
Wenn ich Plex neu starte ist erstmal wieder etwas Ruhe, aber am nächsten mörgen läuft es wieder genau so los und zieht fast 100% CPU
Es wäre super wenn jemand helfen könnte bitte.
liebe grüße aus dem hohen Norden
SvenB
