Playback Error for Live TV via locast2plex
Server Version#: 1.21.1.3876
Player Version#: On Chrome
Tuner Make/Model: locast2plex
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Apologies in advance as I’m a novice. I have been using PLEX for a while and its is an awesome setup and works GREAT!! A year or so ago I moved it to WD PR4100 NAS and it runs great!
A few days ago I discovered locast2plex and since I’m a donating member of Locast to get local channels this was a dream come true… local channels in PLEX with DVR - woohoo…
So updated to latest version of server, downloaded locast2plex, running python 3.8 I launch it and it seems to run in a command prompt window. I got the DVR configured and it pulls the channel guide. I click on any channel in a browser player and get the dreaded playback error. It took me a while to get here (python upgrade, leveraging config.ini instead of command line switches, I even popped in the latest version of ffmpeg) but I’m not being able to play any channels…
PLEX on NAS (WD PR4100) at 192.168.1.250
LOCAST2PLEX on Windows10 at static IP 192.168.1.200
LOCAST2 PLEX Config.ini
[main]
#uuid=<note: automaticially created if nonexistant>
plex_accessible_ip = 192.168.1.200
locast_username=@.com
locast_password=
Here is what I see on the locast2plex windows (clearly you can see it is trying to send a channel back)
Initiating Locast2Plex v0.6.2
Opening and Verifying Configuration File.
c:\lc\locast2plex\config\config.ini
c:\lc\locast2plex\config.ini
Loading Configuration File: c:\lc\locast2plex\config.ini
Tuner count set to 3
Server is set to run on 192.168.1.200:6077
No UUID found. Generating one now…
UUID set to: kjjxmhmn…
Getting user location…
Getting location via IP Address.
Got external IP 47.36.48.247.
Got location as Atlanta - DMA 524 - Lat\Lon 34.1065-84.0335
Logging into Locast using username @.com…
Validating User Info…
User Info obtained.
User didDonate: True
User donationExpire: 2021-01-23 13:54:45
Starting First time Stations refresh…
Checking FCC facilities database for updates.
Cached facilities database is current.
Getting list of stations based on DMA…
Found 36 stations for DMA 524
Starting Stations thread…
Starting device server on 192.168.1.200:6077
Now listening for requests.
Starting SSDP server…
Starting First time EPG refresh…
FROM CACHE: c:\lc\locast2plex\cache\524_epg\01-11-2021.json
FROM CACHE: c:\lc\locast2plex\cache\524_epg\01-12-2021.json
FROM CACHE: c:\lc\locast2plex\cache\524_epg\01-13-2021.json
FROM CACHE: c:\lc\locast2plex\cache\524_epg\01-14-2021.json
FROM CACHE: c:\lc\locast2plex\cache\524_epg\01-15-2021.json
FROM CACHE: c:\lc\locast2plex\cache\524_epg\01-16-2021.json
Registering upnp:rootdevice (http://192.168.1.200:6077/device.xml)
Starting EPG thread…
Locast2Plex is now online.
192.168.1.200 - - [11/Jan/2021 00:27:07] “GET /device.xml HTTP/1.1” 200 -
Unknown request to /favicon.ico
192.168.1.200 - - [11/Jan/2021 00:27:07] “GET /favicon.ico HTTP/1.1” 501 -
192.168.1.250 - - [11/Jan/2021 00:27:14] “GET /discover.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:27:14] “GET /lineup.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:27:14] “GET /lineup_status.json HTTP/1.0” 200 -
Getting station info for 1571261945557…
Determining best video stream for 1571261945557…
Found 3 Playlists
1571261945557 will use 1280x720 resolution at 2700000bps
192.168.1.250 - - [11/Jan/2021 00:27:15] “GET /watch/1571261945557 HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:27:16] “GET /discover.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:27:16] “GET /lineup_status.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:28:19] “GET /device.xml HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:28:19] “GET / HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:29:46] “GET /device.xml HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:29:46] “GET / HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:31:12] “GET /device.xml HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:31:12] “GET / HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:32:49] “GET /device.xml HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:32:49] “GET / HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:34:28] “GET /discover.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:34:28] “GET /lineup.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:34:28] “GET /lineup_status.json HTTP/1.0” 200 -
Getting station info for 1571261955963…
192.168.1.250 - - [11/Jan/2021 00:34:29] “GET /device.xml HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:34:29] “GET / HTTP/1.1” 200 -
Determining best video stream for 1571261955963…
Found 0 Playlists
No variant streams found for this station. Assuming single stream only.
192.168.1.250 - - [11/Jan/2021 00:34:29] “GET /watch/1571261955963 HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:34:30] “GET /discover.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:34:30] “GET /lineup_status.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:34:49] “GET /discover.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:34:49] “GET /lineup.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:34:49] “GET /lineup_status.json HTTP/1.0” 200 -
Found 3 Playlists
192.168.1.250 - - [11/Jan/2021 00:34:49] “GET /watch/1571261945557 HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:34:51] “GET /discover.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:34:51] “GET /lineup_status.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:35:35] “GET /device.xml HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:35:35] “GET / HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:36:56] “GET /device.xml HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:36:56] “GET / HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:38:38] “GET /device.xml HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:38:38] “GET / HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:39:42] “GET /device.xml HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:39:43] “GET / HTTP/1.1” 200 -
192.168.1.250 - - [11/Jan/2021 00:39:45] “GET /lineup.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:39:45] “GET /discover.json HTTP/1.0” 200 -
192.168.1.250 - - [11/Jan/2021 00:39:45] “GET /lineup_status.json HTTP/1.0” 200 -
I feel like I am missing something simple or doing something dumb… I would love to get some advice… I’m not the village idiot (probably making a village idiot mistake) but definitely not as tech savvy as most users here!
Any guidance/advice would be greatly appreciated
