There seems to be a playback error. Its happening again two movies I play on plex and it freezes. Afterward, it shows the playback error. Please plex fix this. Give me an update when it is fix. I tried to watch stay(2005)movie but it freezes and show the playback error. I can see the movie is leaving soon. It did the same thing for the christmas candle movie.
Update: The live tv streaming on Plex also shows the playback error. It freezes. I haven’t seen any fix update. Therefore, I can’t see nothing on plex.
Which part of the setting of Plex app on my smart tv can I set to “Always”. I want to try it if it will work. If it doesn’t work I would have to delete my plex account because I will not be able to see the on demand or live tv streaming.
This won’t help.
Playing the ad-supported media from plex.tv will always require a secure connection. This is part of the DRM scheme which is required by the content owners.
If a TV is too old to handle secure connections, it can unfortunately not use the free content.
I recommend an add-on device, like a FireTV, nVidia Shield, or Apple TV.
For me and many others if playback does not work if you stream via internet on an older smart-TV the only solution is to set “Allow Insecure Connections” to “Always” .
This applies only to content from your own Plex server.
However, OP doesn’t have a server. He’s only using the free-to-watch content from https://watch.plex.tv
Which is only available with DRM protection.
My Lg Smart TV is a 2018 model. Does LG 2018 model is still old? Because I only have a smart tv. If it can’t work, thanks it was great using plex to watch free movies and live tv.
Which part in the Plex app is this part located? Because I went to setting, I don’t see the Allow Insecure connection part in the settings. I don’t know if it is the app update that remove it.
Thanks I tried it. But the advanced section has only Reset app. That only deletes your account and I needed to login. It still didn’t work. I think November Update took all those features away from the plex app advanced settings.
