I have seen similair behavior. For me it was that I selected Play from beginning (a movie in these cases) and it actually started a couple of minutes before the end of the movie. I noticed at at these times if I monitor the server the transcoder keeps running also after I stop the movie. Starting the movie again does make it start from the beginning but now I have two transcoder processes running.
Same here. And stopping and starting again starts from the beginning
Got the same behaviour. I watched two movies and both started near the end.
it's pretty much this:
Although I can't check if I have "two transcoder processes" running because I have no idea how to check that.
I've only seen this once and I've been using the app quite a bit. If I get it to happen again I'll try to grab the logs.
I've also noticed that once in a awhile when you have a movie that is partially watched, it will start from the beginning and not ask if it should resume or start at beginning. Possibly related to this issue.
Same as above. I had this happen once on one file, it happened 3 times in a row, and then it started working again. I will get logs the next time it happens.
So I had it happen again. The beautiful thing is that I was able to get logs. It starts at the 20:26 part. For some reason it jumps right to 88.8 right off the bat from 0.1 and 0.2 progress on the transcoder. If it happens again, I will see if it goes right back to the 88.8. It's transcoding as I can see through Plex/Web and I can also see the Transcoder process in the logs. Like I said, this rarely happens, but hopefully logs can assist.. if it helps, this was an 480p AVI file (h264 with AAC). I will see if I can get it to happen again, and see if it's when something is transcoding vs. direct play.
Also, more information. This is my first time ever watching the movie, not sure if that helps. Also, I really think it has something to do with that 88.8 progress%. Just seems too random. From previous posts (and the last time it happened for me), it was more than 4/5's done (hence the 88.8). It's hard to replicate, but I hope to have it happen again so I can provide more logs.
