Playback stopping and not buffering
Server Version#: 1.19.5.3112
Player Version#:1.19.5.3112
This issue started a week or so ago. Not really sure if its version dependant or not. Server is running on unraid witht 4 disks dedicated, with quicksync as the transcoder. Player is on a new Shield tv pro out of the box.
Media will start and after a few minutes stop. The play bar isn’t buffering the next scenes and the only way to get it to play again is to back out and back in. Recently its been showing the your connection is not fast enough. The server and player are both wired directly to the same l2 switch. Router is pfsense if it makes a difference. Both are on the same subnet etc. I have attached logs, the last freeze up happened in the last 4-5 minutes of the log.
Plex Media Server Logs_2020-07-23_15-39-08.zip (1.1 MB)
