Playback while at work
Hi hoping to get some help/advice while I’m at work and connected to Wi-Fi I can transcode to all options but when I’m on my mobile data I can only choose 2mbps or original
Is there a way I can change this? I have limit mobile data turned off
Get a better cell signal?
I once worked at a place that had really crappy cell service. Perhaps “at work” you don’t have that many bars (there is something ironic about that statement!). What does speedtest.net reveal?
  1. In the Plex app settings on the phones, check the setting for Remote Streaming Quality.
    The default is 2 Mbps. Change it to Maximum.
    Android: Settings → Quality → Remote Streaming Quality.
  2. Disable Auto Adjust Quality in the mobile Plex apps if it is enabled.
  3. While streaming over the mobile network, monitor playback via Plex Dashboard → Now Playing + Expanded View.
    Is the connection Remote or Indirect?
    If Indirect, the connection is using Plex Relay, which is limited to 2 Mbps, and Remote Access is not functioning correctly between your server and your phone.
