Player cannot fullscreen
Hello guys, i need some help here.
I tried to view with fullscreen using chrome and firefox, but seem like its not working. May i know how to fullscreen please?
Thanks.
Ok this is weird, i tried access Plex using localhost and fulscreen function is working but access using domain (from outside) fullscreen not working.
Is this normal?
When i press the button (which is in the down right corner) it goes in full screen mode in Chrome on Windows 10.
Hope it helps.
Hope it helps.
No, its not working when using domain but its working with localhost.
Hmmmm, same problem as here and until now no solution?
https://forums.plex.tv/discussion/163284/chrome-full-screen-problem
Still strange the issue is not everywhere.
Here it works like a charm! Good luck!
Did you access using domain with custom port at the end of URL?
My URL is plex.MyDomain.net
I used app.plex.tv/web/app# and 192.168.1.11:32400/web/index.html and they both worked fine. I don’t have a own domain in place so i cannot test that.
Using Plex I have had no issues with going full screen until it updated server and player yesterday. It will not Fullscreen via player or Windows app. Very frustrating. At least I can use Chromecast until fix comes out.
