Player keeps Spartacus Season 1 episode 13 out of the other episodes
Server Version#: 1.13.5.5291
Player Version#: 3.63.1
For some reason, when I look at the TV shows, episode 13 of the first season of Spartacus appears next to the collection of previous episodes. I double checked the name on the server. I even copied the name from episode 12, pasted it to episode 13 and then changed 12 for 13, the player still shows episode 13 next to the collection of previous episodes:
54
Here is the content of Season 1 on the server:
56
Why is it doing this?
That is recently added. What is shown depends on when you added these files. If an episode is added on it’s own (1 file) then it will show that episode. If you add multiple episodes from a season at the same time, it will show “Season X”. If you add multiple seasons, it will list the Show.
Thanks. I moved the Spartacus folder out of the TV Shows folder, then put it back and now I only see the entire series. Funny because it says “13 episodes” but there is a number in the right corner that shows “12”…
The number in the corner is how many unwatched episodes, not how many got added. The watched status does not get reset when you remove it from PMS so if you had already watched 1 episode, that episode would remain watched and your unwatched count would be 12.
Oh ok, thank you!
