EDIT: Disregard this post. I tried a few more times and I couldnât get playlists to play more than one item with the play or shuffle button. Leaving the post below for history
I tried a bit more fiddling around with the playlists:
The playlist seems to play another item on the list if you start the playlist with âPlayâ or âShuffleâ.
*The playlist will stop after 1 item is played if you select the item directly from the playlist. It ends with the âJust Playedâ screen and stays there. *
Last attempted versions: Server is a Synology NAS. Plex Server version 1.25.3.5409 Player is a NVidia Shield Pro. Plex Player version 8.29.0.30247 beta
Apparently no one from Plex monitors these posts. I tried several times to get a response from a mod and so far have not received ONE response! Keep up the good work Plex!
Can we have a mod or anyone from the plex team taking a look at this bug ? its been more than 2 months already and still no fix and im being afraid that we cant really hope to have a fix for this bug if no one from the plex team doesnt even take a look at this thread âŠ
Is anyone else seeing this as starting an episode in a show and the next episode doesnât autoplay on completion? I think this is the same issue and iâm seeing it only on nvidia shield
PLex hasnât responded to this post since it started. They clearly donât seem to care. I have a YouTube friend that may do a video on this issue and how Plex refuses to even acknowledge any of this issue. I even wonder if they ever look at this site at all. What good is a forum if no one keeps after it. Such a shameâŠ
PLEX PLayer Log reboot occurs on the following line:
02-24 15:39:07.284 i: Hello, Plex for Android world (debug: false)!
PLEX Server Log shows failure to play on the following line:
Feb 24, 2022 15:39:05.623 [0x7fe136dd1b38] DEBUG - Failed to stream media, client probably disconnected after 393216 bytes: 104 - Connection reset by peer
Really hoping for a fix on this issue.
I do not encounter this problem when I use playlists on my iPad.
