Playlists disappear from PMS
I’m not sure if this is plexconnect or PMS causing the issue but I have experienced this now twice. I create my playlists then they disappear from PMS which causes them to disappear from PlexConnect as well (obviously). What I noticed this time is that PlexConnect was not running currently but I was still in the hijacked app under the playlist tab when I shutdown plexconnect (due to testing new OpenPlex features which included shutting down plexconnect temporarily while testing). Once A few episodes continued to play even though plexconnect was turned off on my mac I started plexconnect back up and then all my playlists disappeared. I would love to give a log but since plexconnect was shutdown it’s basically impossible to do so. I belive it’s due to plexconnect not running yet the appletv was still able to continue playing the playlist which caused the error on pms.
i don't have this problem, but i se other persons playlist on my playlist list.. how is that :O
Playlists are PMS, not user specific - as far as I understand.
Thats what I figured, I'm just lost why when PlexConnect is stopped and a list is still playing thru the list it makes all my playlists disappear entirely from PMS when start PlexConnect back up and I refresh the playlist tab.
Yeah, my comment was to stoffez.
I don't see a connection from (a dead) PlexConnect to the PMS playlists either... do you have that repeatable?
I haven't tested it again (I hate re-doing my playlists). I will test again in the next few days and report back.
