Problem with music playlist sync
Server Version#: 1.20.1.3252
Player Version#: 7.6 on IOS 12.4.8
Since two version on my phone when I download a playlist on my phone. it doesn’t appear on playlist tab in “Downloads & Sync” Tab
Please find attached an example.
I tried fully uninstall the app and re download a playlist with the same result
still nothing… Is it the right place to put a bug?
The problem describe above it’s actually true with anything in the playlist, even with one item.
I’m having the same problem with the iOS app.
So I’ve removed and reinstalled the Plex app and synced two playlists. The items appear in my offline content but not the playlists. In addition many of the items that appear do not actually play.
Chiming in as I also have the same issue and wondered if it was a problem my end… the offline music is all there but playlists are nowhere to be found, even if you try to search the local library
The download and sync show that the content has been downloaded
Is there a way, to contact the dev team for prioritization. I checked the plex’s Gitub and it’s pretty much dead over there.
I hope the next version will correct this.
the new version 7.8 didn’t fix the playlist bug, I still can’t see any playlist. It introduce a regression for me, an admin cannot download anymore an item. The sync button disappear. Anyway, it’s worse and worse version after version on mobile. It’s a shame, and the worse is the forum is the only way to contact the dev teams.
