Please enable tagging (think keywords) of movies
I want to be able to tag or keyword movies so that 1) I have better filtered search abilities and 2) The ability to make custom playlists. For example make a Christmas movies list without having to put all the Christmas movies in their own directory.
https://support.plex.tv/hc/en-us/articles/201272763-Edit-Details
I have the same request, and have read the article. I haven’t used Plex that much, but don’t see a good way to organize movies with tags or keywords. I tried labels, which seem to be designed around sharing, and you can use them in a filter, but not in a search. And filters are annoying. I don’t want to have to drill down through that UI to pick things to filter by every time. I don’t see that you can define a filter and save it for future use, or pin it. I added tag values to the collections field on the tags page, and that’s not useful for filtering or searching.
I think what’s needed is a custom tags field that we can add any arbitrary tag to, which is available for filtering and searching.
Also, we need the ability to define a search and/or filter, and save it and pin it for quick access.
That’s what a ‘smart playlist’ is.
https://forums.plex.tv/discussion/comment/1110287/#Comment_1110287
Thanks @OttoKerner. It looks like the smart playlist handles the saving and pinning request. Now if we could just define custom tags that would work for searching and filtering, it would be perfect.
You can assign ‘collections’ tags for this.
I tried collections tags, and for me, they’re working for filters, but not for search. Also, now having tried out the smart playlist as a means of saving/pinning, I still would prefer that it worked just like a regular filter/search. The UI changes with a playlist. It’s a reasonable way to get the job done if saving filters isn’t feasible for some reason, but it would be neat to have a ‘Saved Filters’ top level menu option where Playlists appears under the Libraries heading. Or if playlists had a property to select how they’re displayed, that would be fine too. I would choose to display it just like the regular movie list that you get when you search or use a filter.
For now, it looks like a combination of smart playlists and collection tags is the best option for me. Thanks again @OttoKerner.
Early 2021 clean-up: implemented (e.g. using collections or sharing-labels)
