update the Plex interface show warning symbol on the episode which has missing file (when it has another alternative format that is not missing).
show a warning message “version missing/unavilable” when hover on the specific episode
show a dashboard page to cleanup missing versions of episodes centrally without this manual show by show episode by episode method.
Change the TRASH icon on the show art to a warning symbol.
It doesn’t make sense you show the trash icon for the whole show just because 1 version of 1 episode is missing
When you dig deeper into the series, does the missing episode show ?
AFAIK, the red trash can will show if something is missing. As you dive deeper into the structure, the granularity refines and identifies the singular item when it gets to the bottom of the pile.
Correct yes let me know if you have trouble replicating.
Unfortunately I fixed it now before taking screenshots etc but you have correctly understood what i described.
PLease include my suggestions from the first post also as all of them would help make the user interface clearer to understand & resolve these issues.
it would be nice to have a “cleanup” page showing missing media etc as a bonus but just improving the error display etc would be great.
Separately I had a weird bug connected to this today:
I deleted a TV show (from the tv show page) - so all 8 episodes gone
using plex TV android app
the show disappears from android app view
I login to plex web browser on computer and the show is visible & has Trash Icon on it.
(This is before I enabled auto empty trash).
I then deleted it again using plex web.
Still strange though that plex web would display the show when it was deleted correctly through PLEX android tv app…
The Plex/web client caches plus it doesn’t update like the dedicated device apps do.
I don’t know why it is that way but it is. I think it has something to do with limitations in the scripting the browsers have (lowest common denominator)
It used to show at the invidual episode level; that was handier when debugging issues when moving media from one drive to another. You definitely don’t want to empty the trash – you lose all the watch data when that happens if the episode is legitimately missing on both sides.
I can understand it being off by default (performance reasons), but if there was an option to turn that on … that would be handy.
