Thanks JJROSS! That worked for me!
I wasnāt really trying to offend anyone here. I was affected by this particular problem too and after all the Android problems and dysfunctional DVR issues for the past 3 years, I finally decided to make the permanent switch to the alternative that I had been running in parallel for a while. If you donāt think that that is appropriate in this forum, itās not my place to disagree with you.
Now Iām having an issue with my libraries rescanning. Nothing happens. If I add an additional source it starts scanning that new folder, but it will not rescan the original folder.
Edit: Restarting PMS seemed to fix it. Magic.
Same thing happened to me. @pMuZy1000 solution worked for me as well.
Thank you! Yes, this did the trick. I was fresking out.
Would love to know how or why this could happen?
Did I miss Plex staffās comment on this, or any attempt whatsoever to help people after their botched update uninstalled many, many peopleās servers?
Or did they just pretend it didnāt happen and leave their customers to fend for themselves?
I didnāt see a post though I could have missed it. I see they pulled the release and updated the release notes to indicate there was an issue but that was all.
You didnāt offend me and Iām sorry if my reply came off rude; I just donāt see how your post was helping anyone and youāre not the first to come into the Plex forums to proudly announce that youāre leaving.
If you want to go, thatās your choice, but thereās no benefit to letting everyone here know and it doesnāt do anything to help address the problem in this thread.
Genuinely I hope the other program works well for you. Best of luck with it.
I have this issue, but I do not have the version 5000 in the Updates folder. Anyone got a copy of the update they can share so that I can Repair my install?
Anyone at all?
I lost my server. Solution indicated above did not work for me. Restore point did not work for me.
Uninstalled everything and installed v1.33.0.2444-a220eae4-x86_64.exe on win10. No wizard pops up to import or create a server.
My Home Screen is empty.
Any help is appreciated.
I have tried uninstalling Plex and installing a new version, which seems to install successfully until you try to launch it. When I try to access Plex via browser, I get a blank white window that never loads. The server is just hung. Anyone here to help?
