So this morning 2-8-19 my Readnas updated. 12 hours later my unraid box shows no updates available in docker but in Plex settings it says there is. Why can’t I update this box? I’m confused. Also all the version on the Plex website still show 1.14.1.5448
Two issues here right? Your unraid docker version is not updating correctly to 1.15.0 and for @TeknoJunky is having problems with the pre-release of ReadyNAS?
For unraid docker - did you upgrade the actual image? what does it say when it start and tries to apply the update?
I’m not sure what you mean by actual image? Typically unraid says there is an update an it let’s me hit upgrade. It hasn’t done that yet even though Plex is saying an upgrade is available.
I mean the docker image. It needs to be updated with docker pull or whatever unraid mechanism there is. What exact docker container are you currently running on?
I’m also on unraid 6.6.7 r2. I just told unraid to force update Plex and it now has 1.15. Not sure why unraid never notified of the update as it did 3 weeks ago.
I am on ReadyNAS 312, firmware 6.9.5. I started the usual upload file to do an update from Version 1.14.1.5488-cc26…to version 1.15.0.647-67e9…
When Is start the file upload, the system returns a message I have never encountered before:
“Installing plexmedaserver_1.15
0.647-67e950f2_amd64.deb also removes Plex Media Server. Do you wish to continue?”
I am afraid of losing all my data, so I guess I should skip this version or is this something new?
