Server Version#: 1.20.2.3402 on Win10 64bit. Plex-Web is Version 4.34.4
Tuner Make/Model: Hauppage WinTv Solo
Guide/Lineup name:
Using XMLTV?: nope
Channel number/Name: UK - Film4 plus others
Hi everyone. On Live TV and DVR if I select What’s On and scroll down to Movies on Later. I begin selecting movies I want to record from TV and click, confirm, etc. Then I realise after spotting this first screenshot something’s up: Plex is allowing me to select simultaneous recordings. Surely that’s a bug and it can’t do that with a single tuner? The second screenshot shows the DVR schedule and it confirms what I thought - there are overlapping recordings that can’t be made?
@sa2000 as you never seem to sleep
have you seen this before? Thanks, Alan.
This is normal behavior. Plex will record whichever one starts airing first. If there are multiples starting at the same time then it will use the priority set in your recordings. Any that can’t record due to conflicts will be recorded when the movie airs again and the cycle repeats.
For recordings which conflict, and for which no alternate airing is available, you should see a resolution dialog when attempting to shedule the conflicting one:
And it should show the conflict in the DVR schedule:
However, yours seems to show a couple of legitimate overlaps on the DVR schedule page:
Does Plex perhaps think you have more tuners available than you actually do? You can see the number of tuners in your Live TV & DVR settings:
Hi, thanks for the reply. I have adjusted any recordings that Plex has highlighted as conflicts already. The remaining ones (where there are still overlaps) Plex doesn’t think there is a problem. Plex also thinks I only have 1 tuner.
Thanks for the reply. I haven’t set any priority so I guess it will just record one of them anyway? The part that doesn’t make sense is that sometimes Plex will recognise that there is a conflict and prompt me and other times do nothing?
And I just checked these two recordings that looked like they overlapped on that first screenshot. The second, Entertainment, is a partial recording, just an hour long instead of two.
