@spikemixture said:
@ladytower said:
@KarlDag said:
@ladytower said:
So does the 7.0 update storage changes make any difference with this problem yet? Supposedly you can increase your storage from internal even for apps and games so does that mean we can add a external and make it the internal storage and plex now use that to store all the data? And Can anyone access the protected space now that the pms saves to in 7.0? Or are we still screwed?! I have the older shield and it hasn’t updated to 7.0 yet so i was curious if anyone has bought the new 2017 released with 7.0 and tried plex with it.As far as I’m aware, adoptable storage is the same in Nougat as it was in marshmallow… So don’t expect a change.
Could be wrong, though.
Well you could with 6.0 yes but it was limited to only some data not all and i was under the impression that with 7.0 you have more control over it using majority of data as internal on any usb device now. But your right i shouldn’t expect them to fix a issue it has had since day 1 lol it is so simple too all plex has to do is change where it is installed to outside protected android folder yet they dont do it and keep pms access dead and **_just moved on to other things like dvr and cloud junk _**rather then fix the amateur problem in device they plugged across all media outlets os a media server device!.
Yep I agree!
Honestly, I think putting PMS on the Shield would be considered as worse junk by most users that don’t own one…
