Plex and Plex HTPC not working on macOS High Sierra
My old install of High Sierra used to run both versions fine.
After a re-install, neither of them open.
A box appears saying that:
Plex cannot be opened because of a problem.
The first part of the crash report seems to be about a Framework problem.
Not sure what to do other than ask here, please, if someone understand what might be going on.
I have the first part of the report and here it is:
Process: Plex [2092]
Path: /Applications/Plex.app/Contents/MacOS/Plex
Identifier: tv.plex.desktop
Version: 1.69.1 (1.69.1)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Plex [2092]
User ID: 501
Date/Time: 2023-05-22 09:19:31.609 +0100
OS Version: Mac OS X 10.13.6 (17G14042)
Report Version: 12
Anonymous UUID: F350D959-1257-3464-CC96-C5E789977EA8
Sleep/Wake UUID: 39D68439-AEA7-446C-91D3-B80AE142FC52
Time Awake Since Boot: 14000 seconds
Time Since Wake: 450 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x4] Symbol missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Symbol not found: _NSAppearanceNameDarkAqua
Referenced from: /Applications/Plex.app/Contents/MacOS/../Frameworks/QtCore.framework/Versions/A/QtCore (which was built for Mac OS X 10.14)
Expected in: /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
in /Applications/Plex.app/Contents/MacOS/../Frameworks/QtCore.framework/Versions/A/QtCore
It looks like Plex have updated some of the external components (Qt framework) to a version that no longer supports Mac OS X 10.13 but require at least 10.14. In that case your best shot will be to rollback to the previous version of those apps and stick with those (or preferably upgrade your system to keep up :wink: )
Thank you, I failed to see the Announcements, but did see that the system requirements, on the download page, still stated High Sierra.
As for upgrading, I am running the latest version of macOS that my system allows.
