Server Version#: 1.20.1.3252
Player Version#: Unsure, I factory reset my Fire Stick and reinstalled it on 07/09/2020 and the issue persists.
I wanted to share some family photos and videos on the TV, but was burdened by the app constantly crashing when navigating between photos in different folders.
I am using the Fire Stick 2. I tried factory resetting the Fire Stick, setting it up from scratch and redownloading the Plex app again but it continued to crash.
I logged in with the administrative/main user for the Plex server.
I can provide logs if you instruct me on how to capture them as the issue is very reproducible
Go into the settings and turn on network logging (it’s on the advanced row). You’ll see a ghosted line of text at the bottom with the URL you need to go to to access the logs.
Then go navigate around / do whatever you need to to cause the crashing.
One that’s done, navigate to the URL from before on a PC on the same local network as the Fire Stick, and copy the logs out into a text file.
Although that’s really just a coincidence. There’s a delay in Amazon publishing new Plex app versions to their store after Plex releases them. The 8.6 app was released five days ago, before you started this thread.
