Plex App not starting properly
So this was working fine but recently I have found that when launching Plex it gives me the spinning loading wheel indefinitely. I have to go back to the dash and quit it then restart it and it works okay. Anyone else seeing this issue?
I get the same issue all the time.I uninstall the app then reinstall from the app store it works fine for a bit then i get the same issue over and over very frustrating.I'm totally computer illiterate so all the fixes in the forums just sound to complicated don't know where to start just wish plex would fix this issue with an update.as i feel i'm wasting my money paying for this app.
We started discussing this here:
https://forums.plex.tv/index.php?/topic/131623-Infinite-spinning-circle-after-console-standby
I still feel like it is not plex, but the xbox’s resume feature. I would uninstall and install, but just try a soft reboot via the settings app and the power settings. There is an option to restart now.
I do this every couple of days it seems. The issue goes away if I change from instant on to power saving. The problem is, though, it takes so damn long to reboot. But it is not the end of the world. At least for me.
Philip
