I unzipped them and they worked.
There is this, Core Manager for Plex Arcade.
Check your PMS logs (or upload them here). It should say exactly where it is looking for that file.
The folder needs to be called āGame Coresā with an s on the end.
Also, you need to verify that it is the actual correct PMS data directory.
Finally, in the XMl only include the core name and NOT the .dll at the end.
Just follow their guide, I had it working in no time at all.
