Server Version#: 1.21.2.3939-3945797bd
Player Version#: 7.12
Subscribed to Plex Arcade and linked Parsec account. When trying to play any game I get an error message that says “An active Plex Arcade subscription is required for game playback”.
Hey, I was able to get around that by installing the new Plex Server update(took 3 tries kept erroring out), then quiting Plex and restarting and it worked.
I can now see and even start the games on my AppleTV but can’t seem to figure out how to get past the welcome add coins screen on any of the games.
Try refreshing Web or you might even need to restart PMS.
Games that require a coin, you need to actually add coins which is done with the “select” button. The actual button may change depending on your actual controller. Once you have coins, then you can hit start to play.
I’m having the same issue, where I can launch the games, but cannot get past the Add Coins screens. No keyboard functions appear to work.
How do you “add coins” in a Chrome web browser? Is there a key “map” of some sort somewhere for reference?
Keymap is at https://docs.libretro.com/guides/input-and-controls/#default-retroarch-keyboard-bindings.
tl/dr Shift = Select
