Plex Binding for Home Automation
Hello,
I'm looking for a interface to connect Plex Client to my home automation (openHAB). openHAB is a home automation platform, which supports http requests or extra developed bindings.
Is there a developer, who is able to build a binding, which connects Plex to openHAB (www.openhab.org).
Kind regards ,
Michael
I'd like to do the same, I've come this far:
play/pause  works via http:
http://:32400/system/players//playback/play
http://:32400/system/players//playback/pause
you can get the status via:
http://:32400/status/sessions/
this will get you an xml document which then needs to be mapped via xslt mappings. this is where I fail...
I would like to extract whether something is playing, maybe the title and also which client
here is an API documentation: https://code.google.com/p/plex-api/w/list
Hi there,
It there any way of starting to play a particular music playlist by http commands?
Thanks!
Sasha
It would be epic if they would do a plugin that would let you set cues for hue etc in the file metadata…
Did someone from this thread end up developing this?
i have openhab installed on my synology and have some bindings working that i was able to install via the UI. But I can figure out how to install the plex binding. One of my goals is this…https://www.youtube.com/watch?v=igAUFCZ-zXc
