PlexMediaServer doesn't see subfolders under NFS-mount
Server Version#: 1.32.6.7557
My plex is running in a proxmox-container with a working mount to my NAS. The mounted-directory and all of it’s subfolders have the owner plex:
8 drwxrwxrwx 5 plex plex 4096 May 1 2020 plex, then
20 drwxrwxrwx 426 plex plex 20480 Sep 28 12:27 Movies and e. g.
4 drwxrwxrwx 3 plex plex 4096 Aug 24 11:10 'Particular movie'
But when I try to add the library in Plex-configration UI I’m able to select /mnt/plex, but not behind that (/mnt/plex/Movies). And, if I use just /mnt/plex, Scan Library stops after half a second…
Why? Thank you!
Really no idea?
Really … Already documented :slight_smile: :rofl:
Search is your friend:
Being ProxMox, you mount it INSIDE the VM (the VM itself holds the mount)
