Server Version#: 1.21.1.3830
Player Version#: 4.43.4
I run a server off a seedbox. Due to that reason, I can’t follow the proscribed folder structure, else the seeding will stop. The issue I am having is that Plex wrongly categorized movies that have a year in the folder name not separated by a dot as TV series. For example, it will properly categorize a movie from a folder titled “Ad.Astra.2019.1080p.WEB-DL.DD5.1.x264-CMRG” as a movie. But it will then go on and categorize a movie from a folder titled for example “Avengers-Infinity War 2018 brrip hevc-d3g” as a TV show. I have no control over how the folders are named as those are created by an uploaders. And renaming the folders manually also doesn’t seem to work, at least AFTER Plex already added the files to the library. And I also can’t delete the files and add them again either.
My question is: is there any way to manually re-categorize erroneous entries? Or must I live with this mess forever? Thank you in advance for any suggestions!
