In January, a post was posted on this forum to ask the plex to use the tvdb agent as a movie agent.
However, after 90 days, I can’t write any more, so I’ll post it separately.
I need tvdb as move agent.
I don’t know if TMDB works fine in English speaking countries, but it doesn’t work at all in my Korean speaking countries.
Let’s list cases that don’t work.
The title of the movie contains a number.
In this case, any movie with a number in the title of the movie from that year will be matched.
For example, cars 2. It is written in Korean as “카 2”. At this time, it is matched with a movie that contains “2” among the movies in 2011. -
There is a Korean title in TMDB, but the plot is not translated into Korean in TMDB.
In this case, even a well-translated title is changed into English. -
If there are no movies in TMDB, it is often matched with other movies…
Even if there is data in TMDB, it may not match.
In this case also on tvDB. But on tvDB it is fine.
The reason is that tvDB has id.
Exactly TMDB also has an id, but it cannot be searched by id in the plex.
For tvDB, if you search for movies on Google or tvDB homepage, the value of THETVDB.COM SERIES ID is displayed.
Enter this number in plex “match …” to search.
" 하이바이, 마마!" is displayed even if you enter 373415 in the Title of the match.
Plex tvDB Match with tvDB ID -
For TMDB, if I put 10 movies in the case of 1,2,3, I should check if 10 items matched properly.
I should compare the title of the file and the title of the plex library to see if other movies matched.
Even if plex have a poster, i should make sure that the title has not changed in English.
Like TMDB, tvDB may not found match database.
But unlike TMDB, it doesn’t match wrong.
So I only need to check movies without posters.
In short, tmdb match even if doesn’t match
This is because tmdb needs to check all the videos I added.
If tvdb agent for movie comes out, I would be really happy.
