Server name NUC, currently unable to download certificate-
Oct 04, 2020 21:36:23.459 [0x7f075d7fa700] ERROR - CERT: Could not fetch certificate from the cloud: 404
Oct 04, 2020 21:36:27.115 [0x7f077529e700] ERROR - CERT: Could not fetch certificate from the cloud: 404
Howdy, after restarting a few times I am still having an error, but a new one: Oct 04, 2020 12:42:46.430 [0x70000bbdf000] ERROR - CERT: PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure Oct 04, 2020 12:42:46.430 [0x70000bbdf000] ERROR - CERT: Found a certificate, but couldn't install it.
and then after another restart back to: Oct 04, 2020 12:52:24.223 [0x70000d13e000] ERROR - CERT: Could not fetch certificate from the cloud: 404
Here’s the openssl result on osx 10.12.5: CONNECTED(00000003) 55791:error:140790E5:SSL routines:SSL23_WRITE:ssl handshake failure:/BuildRoot/Library/Caches/com.apple.xbs/Sources/OpenSSL098/OpenSSL098-64.50.6/src/ssl/s23_lib.c:185:
No luck with the restart. If I attach the logs here is there anything I need to remove from them for security reasons or can I send you them privately?
