Ok, I managed to get secure connection working again.
The log kept complaining about this:
CERT: incomplete TLS handshake: sslv3 alert certificate unknown
I saw that some people managed to get the PMS to refresh its certificate by removing (with a backup) the Preferences.xml file and reclaiming the server. So that’s what I did. Since then, I am able to connect securely to my PMS again.
Still, the remote access configuration says that my PMS is unavailable remotely, it show the correct internal IP address and port and the correct external IP address but the external port seems stuck with a 0.
I tried connecting with my apps (Android, Android TV and iOS) and they all work correctly locally.
Remotely, iOS seems to work correctly although it was slow to load the home screen but I am still able to access and stream my content. Android is able to access the home screen remotely but it seems to be unable to stream anything. It starts the stream, but you just get the circle indefinitely. In the log, you get this while trying to start the stream:
Oct 01, 2020 09:17:04.350 [0x7f2daeffd700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 01, 2020 09:17:04.350 [0x7f2daf7fe700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 01, 2020 09:17:04.622 [0x7f2d71ffb700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:04.704 [0x7f2d597fa700] DEBUG - [Transcode] Transcoder segment range: 0 - 22 (22)
Oct 01, 2020 09:17:04.706 [0x7f2d70ff9700] DEBUG - [Transcode] Transcoder segment range: 0 - 23 (22)
Oct 01, 2020 09:17:06.125 [0x7f2d717fa700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:06.623 [0x7f2d717fa700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:07.900 [0x7f2dadffb700] DEBUG - NetworkServiceBrowser: PLAYER departed after not being seen for 182.007240 seconds: 10.72.0.51
Oct 01, 2020 09:17:08.125 [0x7f2d5bfff700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:08.623 [0x7f2d94ff9700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:10.126 [0x7f2d5bfff700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:10.624 [0x7f2d71ffb700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:12.126 [0x7f2d717fa700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:12.624 [0x7f2dadffb700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:14.127 [0x7f2daffff700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:14.625 [0x7f2d377fe700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:16.128 [0x7f2dadffb700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:16.625 [0x7f2dadffb700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:18.128 [0x7f2d727fc700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:18.626 [0x7f2d94ff9700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:20.128 [0x7f2d94ff9700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:20.626 [0x7f2d727fc700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:22.129 [0x7f2d727fc700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:22.129 [0x7f2d727fc700] DEBUG - [Transcode] Streaming Resource: We’ve been measuring for 60s, so changing to client buffered on a9b2cff187776eaf-com-plexapp-android with an estimate of 0kbps
Oct 01, 2020 09:17:22.627 [0x7f2daffff700] DEBUG - [Transcode] Streaming Resource: Estimated bandwidth for a9b2cff187776eaf-com-plexapp-android to be 0kbps over 20.00s
Oct 01, 2020 09:17:22.627 [0x7f2daffff700] DEBUG - [Transcode] Streaming Resource: Segments have been delayed segment for 0.00 and last request was 60.15s ago, so changing to client buffering on a9b2cff187776eaf-com-plexapp-android
I am still trying to figure out why is the remote access marked as unavailable.
