Can't enable Remote Access
Server Version#: 1.20.1.3252
Player Version#: 4.34.4
Server was up&running from few month, after an update of ubuntu server and a reboot the remore access doesn’t work, i’ve made the nat rule on my firewall (pfsense), and the port result open from outside, but i can connect to the server only in not safe mode, how i can solve my problem? I have to disable safe connection, only with this setting disable i can reach the server from outside, but not from apps like plexamp and plex for android.
@chuckpa i’ve seen the problem on my log “CERT: Could not fetch certificate from the cloud: 404”
Maybe i need refreshed certificate or cleared?
@chuckpa
here the log
Oct 02, 2020 16:37:51.844 [0x7f742bfff700] Attenzione — NAT: PMP, timed out waiting for response.
Oct 02, 2020 16:37:51.858 [0x7f742bfff700] Errore — Error issuing curl_easy_perform(handle): 60
Oct 02, 2020 16:37:51.858 [0x7f742bfff700] Attenzione — HTTP error requesting GET https://82-54-127-184.8cb4ffd2eb74403f8d05d4d414a2113b.plex.direct:45633/identity (60, SSL peer certificate or SSH remote key was not OK) (SSL: no alternative certificate subject name matches target host name ‘82-54-127-184.8cb4ffd2eb74403f8d05d4d414a2113b.plex.direct’)
Oct 02, 2020 16:37:52.283 [0x7f740cff9700] Attenzione — NAT: PMP, timed out waiting for response.
Oct 02, 2020 16:37:52.295 [0x7f740cff9700] Errore — Error issuing curl_easy_perform(handle): 60
Oct 02, 2020 16:37:52.295 [0x7f740cff9700] Attenzione — HTTP error requesting GET https://82-54-127-184.8cb4ffd2eb74403f8d05d4d414a2113b.plex.direct:45633/identity (60, SSL peer certificate or SSH remote key was not OK) (SSL: no alternative certificate subject name matches target host name ‘82-54-127-184.8cb4ffd2eb74403f8d05d4d414a2113b.plex.direct’)
Oct 02, 2020 16:38:07.087 [0x7f73f17fa700] Errore — SSDP: Error parsing device schema for http://192.168.2.61:49153/description0.xml
Oct 02, 2020 16:38:37.167 [0x7f73f17fa700] Errore — SSDP: Error parsing device schema for http://192.168.2.61:49153/description0.xml
Oct 02, 2020 16:38:37.599 [0x7f740d7fa700] Attenzione — MyPlex: attempted a reachability check but we’re not yet mapped.
Oct 02, 2020 16:38:37.631 [0x7f7429ffb700] Attenzione — MyPlex: attempted a reachability check but we’re not yet mapped.
Oct 02, 2020 16:38:52.415 [0x7f742affd700] Attenzione — NAT: PMP, timed out waiting for response.
Oct 02, 2020 16:38:52.427 [0x7f742affd700] Errore — Error issuing curl_easy_perform(handle): 60
Oct 02, 2020 16:38:52.427 [0x7f742affd700] Attenzione — HTTP error requesting GET https://82-54-127-184.8cb4ffd2eb74403f8d05d4d414a2113b.plex.direct:32400/identity (60, SSL peer certificate or SSH remote key was not OK) (SSL: no alternative certificate subject name matches target host name ‘82-54-127-184.8cb4ffd2eb74403f8d05d4d414a2113b.plex.direct’)
Oct 02, 2020 16:38:53.083 [0x7f73c97fa700] Attenzione — NAT: PMP, timed out waiting for response.
Oct 02, 2020 16:38:53.093 [0x7f73c97fa700] Errore — Error issuing curl_easy_perform(handle): 60
Oct 02, 2020 16:38:53.093 [0x7f73c97fa700] Attenzione — HTTP error requesting GET https://82-54-127-184.8cb4ffd2eb74403f8d05d4d414a2113b.plex.direct:32400/identity (60, SSL peer certificate or SSH remote key was not OK) (SSL: no alternative certificate subject name matches target host name ‘82-54-127-184.8cb4ffd2eb74403f8d05d4d414a2113b.plex.direct’)
I have an issue also with remote access post this latest update. for me its running on Windows 10. Remote access working fine for years, the a couple of friends complained the couldnt access Plex. On checking the remote access it was showing red, disabling and enabling it would go green for 10 sec then switch back to red, no remote access. I tried disabling my UPnP on the router, manually set the port forwarding and set the port manually. Still the same issues, strangely he can connect via their browser, but their Roku is failing. For me on my internal network my Rasplex (Pi) devices are failing, but the Samsung TV app is fine, as is browser access. Will be rolling back to see if it addresses the issue.
hola llevo 4 o 5 dias que no me funciona el acceso remoto alguien me puede ayudar?? gracias
@deathwalker80
Which server please ? (One appears dead)
como miro eso??
Sukopro
Please restart the server.
Wait 2 minutes
Now download the logs ZIP file
Attach please.
I will look and see if you have the certificate error or something else.
ya lo he reiniciado y me descargado el zip donde meto el archivo que ai??
Drag the ZIP file into this Reply window.
Allow it to upload completely.
Now click “Reply”
Plex Media Server Databases_2020-10-02_23-28-28.zip (28.2 MB)
I’ve got a similar issue on Windows, since restarting my server a couple nights ago, remote access just won’t work. I opened a separate thread, but if I should close that and track here, let me know. Thanks!
@Sukopro
@Devill819
Have you examined the logs?
Do they show a 404 error while attempting to obtain a certificate?
If so, please join us here.
Plex Media Server Logs_2020-10-03_00-34-50.zip (6.4 MB) perdon soy un poco noob
@ChuckPa, I’m new to troubleshooting on Plex, been pretty steady so far. Is there a quick way to get a clean error log? Or should I just download the log that’s currently there to review?
chuckpa tengo que hacer algo mas o sigo esperando?
I started having problem as well over the last 2 days. What do you need to check to see if I am having similar problems to everyone else?
@R2D2_Lib
The best way to help us figure it out is:
  1. Settings - Server - General - Show Advanced
    a. DEBUG logging ON
    b, VERBOSE logging OFF
  2. Save
  3. Restart PMS
  4. Wait 1 minute
  5. Download the logs
  6. Attach the ZIP file here
Ok I just did the steps outlined. Attached my logs. R2D2_Lib_Plex Media Server Logs_2020-10-02_22-49-10.zip (1.5 MB)
Thanks for the logs.
There is no clear error regarding the certificate but also no clear success.
It’s using the intermediate certificate.
It can’t establish itself (Map to a specific IP address) with Plex.tv therefore it won’t enable Remote Access
Oct 02, 2020 22:47:06.587 [2924] DEBUG - MyPlex: async reachability check - current mapped state: 'Not Mapped'.
Oct 02, 2020 22:47:06.587 [2924] WARN - MyPlex: attempted a reachability check but we're not yet mapped.
Oct 02, 2020 22:47:06.588 [2924] DEBUG - EventSource: Successfully connected to 172.105.97.53.
Oct 02, 2020 22:47:06.837 [2568] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/server/webhooks?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 02, 2020 22:47:06.893 [11936] DEBUG - NetworkServiceBrowser: SERVER arrived: 192.168.1.187 (R2D2)
I’ve reset the certificate to see if this is another manifestation of the same problem we’re seeing in Linux.
Please restart the server and advise.
