Plex Certificate "404" -- Unable to obtain Certificate from cloud
@ChuckPa
Same issue as the rest getting 404
name=“Synology-NAS”
@quekky
Certificate reset
Restart the server.
Working great thanks .
here is the latest log. My remote is still not working. Thank you Plex Media Server Logs_2020-10-04_10-11-23.zip (5.1 MB)
@Erics347
PLEASE turn VERBOSE OFF
I can’t use what you’ve given me.
Please turn off - save the change
Restart PMS
Let it sit completely idle for 2 minutes
Download the logs
Attach the ZIP
Ok, thank you for your pertinence. I completed those steps. Here you go. Thank you very much.Plex Media Server Logs_2020-10-04_11-29-14.zip (4.7 MB)
Hi @ChuckPa, I am also having problems with people outside my plex home accessing server.
Me and other members of plex home can access server from remote locations but others can’t.
I have the following in my logs:
[CERT/OCSP] CERT: Could not fetch certificate from the cloud: 404
CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Is it possible this is the same problem?
Happy to send full logs.
Thank you for any help!
@MCH01
That might be the other problem being seen.
How about we take a shot at doing this step. We can defer to the Plex.tv team if this fails.
I see your Synology NAS (current) and two older ones.
Would you like me to remove those two older ones while there?
@Erics347
When you changed the flags to turn verbose logging OFF, did you remember to SAVE the changes (at the bottom) ?
It looks like you didn’t (I got a log full of Verbose again)
Let’s try something.
  1. With this new certificate now in place
  2. Turn off Remote Access
  3. Wait 3-5 minutes for Plex.tv and PMS to be fully in sync with that
  4. Enable Remote Access again.
What I’m seeing is that it’s attempting to enable Remote but Plex.tv doesn’t understand why.
Oct 04, 2020 11:25:58.502 [350700] DEBUG - HTTP 422 response from POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct 04, 2020 11:25:58.502 [350700] DEBUG - MyPlex: Published Mapping State response was 422
Oct 04, 2020 11:25:58.502 [350700] DEBUG - MyPlex: Got response for cca1cae9777989fba482c9758cf7430bedb0b3c2 ~ registered :0
Oct 04, 2020 11:25:58.502 [350700] DEBUG - MyPlex: updating mapped state - current state: 'Not Mapped'
Oct 04, 2020 11:25:58.502 [350700] DEBUG - MyPlex: mapping state set to 'Not Mapped'.
Oct 04, 2020 11:25:58.502 [336208] DEBUG - MyPlex: async reachability check - current mapped state: 'Not Mapped'.
Oct 04, 2020 11:25:58.502 [336208] WARN - MyPlex: attempted a reachability check but we're not yet mapped.
Oct 04, 2020 11:25:58.502 [336208] DEBUG - EventSource: Successfully connected to XXX.XXX.XXX.XXX.
Yes I saved the changes. I’ll try that and let you know what happens. Thank you very much for all of your help. Greatly appreciated.
Hmmmm, Still unable to access
when you can get a set of logs which do not contain all the VERBOSE statements, please attach it.
I will forward it directly to the Plex.tv team .
Yours is one of several I’m seeing which appears to be a race condition caused by the outage and in need of their assistance to correct and prevent from happening again.
ok, thank you
Heres another set of logs. Plex Media Server Logs_2020-10-04_12-03-04.zip (2.6 MB)
Yes please!
Plex.tv guys are now looking at the remote access issue.
This thread is the 404 - cert issue.
Let’s not cross polute please.
Remote Access here please:
I have created another thread for the 422 issue (I hope that is OK).
@ChuckPa Howdy, I too am getting this 404 cert error. Can you please reset for ‘hoohoohome’. Thank you!
@markario
Shut it down please.
I will go clear it now.
You can restart when I return.
@markario
Certificate cleared.
you may restart it now.
