Hi @ChuckPa I am on the same boat - “ERROR - CERT: Could not fetch certificate from the cloud: 404”
Could you help me too pls? Can’t PM you…
Thx
Hey @chuckpa I have also been experiencing this issue, can you kick my certificate?
Thank you!
@martyzeq,
Which server name please?
@sstuetzel,
Done. Please restart the server
Hey mate, I am also getting the “CERT: Could not fetch certificate from the cloud: 404” error for the last couple of days. Any chance you can assist?
Cheers
Please restart the server.
If it fails to correct the problem , download and attach the logs.
amazing - that has done the trick!
many thanks and enjoy the weekend mate!
Great, thanks worked
@chuckpa Seem to be having this issue as well.
Which server please (name)? I see two
There should only be one? So that’s odd, but the one named MYZT.
Oh that was really old. Is there a way to “kill” that one? Cause I don’t even think I have that hardware anymore.
Done.
And this worked, thanks so much!!!
@ChuckPa Mine as well please!
“CERT: Could not fetch certificate from the cloud: 404” in my logs.
Logs enabled and collected. While its not either of the error codes you mentioned, its still a certificate error – ERR_CERT_COMMON_NAME_INVALID.
Oct 02, 2020 08:15:39.315 [13828] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 08:15:42.784 [10228] WARN - HTTP error requesting GET https://66-235-xxx-xxx.7ef07baa052c418eb26c0d51aa5a27a3.plex.direct:32400/identity (60, SSL peer certificate or SSH remote key was not OK) (SSL: no alternative certificate subject name matches target host name '66-235-xxx-xxx.7ef07baa052c418eb26c0d51aa5a27a3.plex.direct')
Accessing https://app.plex.tv/desktop and showing Chrome dev tools, shows a similar cert issue
@ChuckPa I’m also having the same issue on bevo2 if you would kindly assist me as well.
I need server logs please; not web logs
That SSLv3 error looks like the server and host are fighting.
The specific error you should see for this problem is a ‘404’.
This is why I need to see the server logs, collected about 1 minute after server restart.
@ChuckPa I’m also having this issue!
