Plex Certificate Error
I’ve played with some DHCP stuff on a different computer and ended up hopping on and off it a couple times. Now my Plex fails on remote connections (everything works locally and the plex settings show Remote Access is working). Logs keep showing:
CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?> <errors> <error code="1003" message="API rate limit exceeded"/> </errors>
I’ve tried everything… uninstall reinstall, restored snapshot, updated to DSM 7, uninstalled and reinstalled, rebooted modem, server, plex etc. I’m out of ideas…
It seems time was the missing factor… I’m guessing my rate limit reset overnight and everything seems to be working again
