@per_PLEX_ed said:
By popular demand, the tutorial now contains Plexdrive. I tested it from scratch and it should be without a hitch on Ubuntu 16.04 or higher.
Encrypted storage on the agenda next?
Getting it working with RW system for Sonarr / Radarr is a real pain.
I’m still using Rclone in parallel with PlexDrive for that exact reason. Couchpotato and Sonarr use the Rclone mapped path and Plex uses the PlexDrive path. They both point to the same place on Google. This still results in the occasional ban because Sonarr will read the files too quickly if I’m importing a whole show or season at once. I can’t wait for PlexDrive to add write capabilities! (Or Rclone to add caching!)
Haha For now I’m sorta “tutorialed out” but as I said before, never say never. I didn’t plan to add Plexdrive to the tutorial either and here we are
Would be interested to see how you’re doing it. PM if you like. My setup is extremely complicated and I’m sure it could be better. Not even sure I understand half of it myself as a friend set it up for me.
Struggling to get radarr to replace movies atm but sonarr seems to be OK.
If you used UnionFS-fuse you could avoid being banned as you wouldn’t have to mount gdrive with rclone.
If everyone encrypts their media files this will go the way of Amazon Drive real quick. Don’t encrypt, Google will save space (and a lot of money), everyone will be happy because Google won’t remove unlimited.
Encrypt your documents and personal videos/pictures. Don’t encrypt your tv shows and movies.
I’ll do what I please thank you very much.
It’s going away either way. Only a matter of when.
Just a heads up, if you haven’t already installed plexdrive it’s possibly worth waiting for the next realase which appears to remove Mongodb and use boltdb instead.
At least the people on the plexdrive slack channel are nice and helpful. They helped me upgrade to 4.0.0 from 3 very quickly. I’m sure they can do the same with 4.x
I will also jump on the VPS wagon, just ordered one and hope to be able to set it up soon. Already looking forward to it
Hope that I won’t have too many questions to you guys
Edit:
Gotta say a huge thank you for the guide, went butter smooth on my ubuntu 16.04 VPS. The only hiccup I had was in the starting script of plexdrive the option “–clear-chunk-max-size” is obviously not available anymore and led to a failure of the script. I just deleted, dunno if now my VPS will explode due to that
Can someone point me in the right direction regarding a script (and then setting up that script) to move Sonnarr or Radarr downloaded content from the completed folder on the VPS to Google Drive.
I have a UnionFS mount setup just need a little help on what to do next.
Edit:
It does work…
–clear-chunk-max-size=50G for example works fine for me.
Edit:
It does work…
Strange, gave me an error… If I run ‘plexdrive --help’ it also does not appear as valid option.
