@SIcK said:
However, if I right click on a shared folder, then I only have options to share, move to, add star, change color, download & remove. I do not have an option to make a copy if I right click on a folder. Am I doing something wrong?
Yes, you can’t make copy from Folder, and that’s why I mentioned it’s not worth it, because if you have many folder, it take a lot of time, unless you use that method I mentioned and your file would move and copy in less than 1 day.
@BigStevie1973 said:
Yeah, I see what you mean. You need to go into the shared folder, highlight all files and then right click / make a copy. The downside to this of course is that everything will be named “Copy of …” That said however, I have just found an app add-on for Chrome that allows you to bulk rename files in Google Drive. I haven’t tried it yet but if it does what it says on the tin, it’d be powerful handy!!
You don’t need to to that, all you need to do is just share one folder and then use rclone to copy that main folder and then all of the file would be copy.
@KarlDag said:
I’m pretty sure If you share from Account A to account B, if/when Account gets closed the file won’t be available on Account B anymore. That’s why making a copy is better.
Does rclone need to download/upload the file to so that?
Well that would be case if your file on the Account B be the share file, but when you copy all of them, they would be gone anymore if you lose Account A, because now they owned by Account B.
And no, it’s server side copy, so it won’t use single bandwidth and it’s all on Google, and that’s why it’s pretty much fast, I transferred 60Tb just in 1 day from one Gdrive to another.
@nigelpb said:
rclone needs to download/upload the file. It sounds like making a copy of a file shared from one Google Drive to another creates a snapshot but doesn’t literally make a copy of all the data just copies a link that points to all the data which is why it is so fast.
It does make a copy of it, but because it’s server side you don’t get to download and reupload it again, and on there is no Snapshot, because on the Google file don’t get space on your drive until they owned by the account holder, and when you copying the file, you become the owner of that file and that’s when is Google start counting it towards your storage, so which by what you saying I shouldn’t have any storage used on my second Gdrive, because if it would be snapshot, it shouldn’t use any of my storage quota, but as of right now, I have 60Tb in both of my Gdrive, sync together.
