Plex crashes/does not launch
Server Version#: 1.25.0.5220.de6e6zdf7.this.obviously.needs.to.be.longer
Player Version#: 1.37.0.2706-5b2cfe50
On Windows 11, yes, I know, but I’d like to troubleshoot it regardless.
I run plex media player. It does show up under task manager briefly, then it goes away. I don’t really know which of the 5 dozen places where log are, might be or could be to start investigating.
I guess this might be it, but it seems rather… slim.
Nov 15, 2021 23:27:25.463 [33132] INFO - Starting Plex version: 1.37.0.2706-5b2cfe50
Nov 15, 2021 23:27:25.463 [33132] INFO - Running on: Windows 10 Version 2009 [10.0.22000] x86_64
Nov 15, 2021 23:27:25.463 [33132] INFO - Happy Plexing!
Nov 15, 2021 23:27:25.456 [27736] INFO - [OpenGL] Selected angle renderer.
Nov 15, 2021 23:27:25.456 [27736] INFO - [OpenGL] Default surface format version: 2.0
Nov 15, 2021 23:27:25.456 [27736] INFO - [OpenGL] Selecting surface format version: 3.0; profile: 1
Nov 15, 2021 23:27:25.614 [27736] INFO - [OpenGL] Testing surface format version: 3.0
Nov 15, 2021 23:27:25.614 [27736] INFO - [OpenGL] Setting default surface format
Nov 15, 2021 23:27:25.614 [27736] WARN - [OpenGL] Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Nov 15, 2021 23:27:25.614 [27736] INFO - [Settings] Web inspector port 0
Nov 15, 2021 23:27:25.636 [27736] INFO - [NanoServer] Starting nano server.
Nov 15, 2021 23:27:25.636 [27736] DEBUG - [NanoServer] Setting app support dir to C:/Users/nauip.local/AppData/Local/Plex
Nov 15, 2021 23:27:25.644 [27736] INFO - [NanoServer] Found available port: 32700
Nov 15, 2021 23:27:25.644 [27736] INFO - [NanoServer] Changing nano server port from 0 to 32700.
Nov 15, 2021 23:27:25.644 [27736] DEBUG - [NanoServer] Setting listener port to 32700
Nov 15, 2021 23:27:25.644 [27736] DEBUG - [NanoServer] Setting environment up.
I had rolled back the plex player update that broke things to get it to work (since it was a Plex player that broke it) I ignored new versions until the last day or 2 (it’s been busy) and either Windows stopped being dumb and allowed the Plex player to launch or Plex player stopped doing something dumb and Windows allowed it to launch… or maybe both.
The player version 1.38.something.something is now launching.
Thanks! If I run in to the issue again I will try to remember this.
The same happened here - thanks for the tip - removing the highlander.lock seems to have solved the issue.
I use the Windows 11 browser version (Edge) in order to check the metadata allocated to TV programmes and films.
