Plex crashing after making SSD run a 100% capacity
Server Version#: 1.25.1.5286-34f965be8
Player Version#: 1.38.0.2734-ec4489fe
Plex Media Server Logs_2021-12-02_23-09-16.zip (2.0 MB)
After somtime 20min or less than 24h plex server become anavailable for local and online user. everything work on well on the server or on the associeted NAS. exept the SSD disk on the server (only the plex media server is on this SSD) running at 100% see screenshot below. i have try to stop the process without success the only thing i can do is make an hard restart of the entire server in order to make plex work again.
I have use plex with plex pass for several years now i never have this issue
Thx for your help
Update :
I have try several things :
  • change de SSD and make a new installation = same problem
  • check all HD in the NAS no problem
  • i have disable shedule task and scaning during the day = same problem
  • i have disable intro detection and all optional thing = same problem
    The problem is still here happening at least 10 time per day plz find the problem or at least up a new version no software should push a drive to 100%
i have made a new dl of logs after enable error detail and after rebooting due to the problem
Plex Media Server Logs_2021-12-12_18-39-51.zip (2.9 MB)
I have made the server update 1.25.2.5319
Problems remains…
log on the new version after 3 crashes in less than an hour :
Plex Media Server Logs_2021-12-14_22-46-48.zip (2.2 MB)
i paste here the massage from a other topic in order to keep an history clean of what i have done :
I have try to strat a database optimization first
seems to have trigger the problems :
Start the optimization 30 sec same problemes as usual the plex is still up seem to run but no player are able to connect to the serveur
this task start every night but she is never finish when i check the next morning. as i have the issue even when i do not do maintenance i think it’s a trigger to an undeling issue. I’ll try to make a repair of the DB and keep you in touch
First try : shut down plex server / Pragma integrity check generate my problems SSD runs to
100% i have let it run 1h without result
Second try : shut down plex server / Pragma integrity check - check return “ok” as said in the link i try the recover and it generate my problems see picture
an idea on how to try to uncorrupted the database without using recover command prompt ?
