Plex Crashing on Live TV Playback or Remote Stream
Currently experiencing crashing on all invocations of Live TV Stream (local) and all remote content streaming. This just started happening in the past couple of weeks.
Windows Information:
WindowsBuildLabEx                                       : 18362.1.amd64fre.19h1_release.190318-1202
WindowsCurrentVersion                                   : 6.3
WindowsEditionId                                        : Professional
WindowsInstallationType                                 : Client
WindowsProductName                                      : Windows 10 Pro
WindowsVersion                                          : 1909
CsProcessors                                            : {Intel(R) Core(TM) i3-8300 CPU @ 3.70GHz}
CsSystemType                                            : x64-based PC
Server Version#:1.18.7.2438-f342a5a43
Player Version#: All players (iOS, Apple TV, Web)
Crash Logs
Feb 20, 2020 07:07:48.751 [0504] INFO - Crash Uploader - Platform: Windows ServerUUID: a941f0afde67412134fc1554be30e0fc2431fe4e UserId: REDACTED Version: 1.18.7.2438-f342a5a43
Feb 20, 2020 07:07:48.749 [12664] DEBUG - HTTP requesting POST https://sentry.io/api/1233455/minidump?sentry_key=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Feb 20, 2020 07:07:49.462 [12664] DEBUG - HTTP 200 response from POST https://sentry.io/api/1233455/minidump?sentry_key=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Feb 20, 2020 07:07:49.462 [12664] INFO - Successfully reported fdddcb86-7689-42c9-afab-314e8dbc11ca
Tuner Service Logs
Feb 20, 2020 02:02:19.041 [9188] INFO - Plex Tuner Service v1.0.0.0 - Microsoft PC x64 - build:
Feb 20, 2020 02:02:19.041 [9188] INFO - Windows version: 6.2 (Build 9200), language en-US
Feb 20, 2020 02:02:19.041 [9188] INFO - 4 3696 MHz processor(s): Architecture=0, Level=6, Revision=40459 Processor Identifier=Intel64 Family 6 Model 158 Stepping 11, GenuineIntel
Feb 20, 2020 02:02:19.041 [9188] DEBUG - "C:\Program Files (x86)\Plex\Plex Media Server\Plex Tuner Service.exe" "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private" "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Shared" 1.18.7.2438-f342a5a43 32600 /waitmutex
Feb 20, 2020 02:02:19.041 [11432] INFO - [I] broker_t::start...
Feb 20, 2020 02:02:19.104 [11432] INFO - [I] device_manager_t::init.
Feb 20, 2020 02:02:19.104 [11432] INFO - [I] device_manager_t::init. Initialize provider manager
Feb 20, 2020 02:02:19.104 [11432] INFO - [I] device_manager_t::init. Initialize all device auxes
Feb 20, 2020 02:02:19.104 [11432] INFO - [I] dvb_device_factory_t::get_aux_list
Feb 20, 2020 02:02:19.104 [11432] INFO - [I] bda_aux_t::init
Feb 20, 2020 02:02:19.260 [11432] INFO - [I] web_server_t::start. Starting web server on port 32600
Feb 20, 2020 02:02:26.332 [9540] INFO - [I] web_service_t::process_device_discovery
Feb 20, 2020 02:02:26.332 [9540] INFO - [I] device_reactor_t::get_device_list ()
Feb 20, 2020 02:02:26.332 [9540] INFO - [I] dvb_device_factory_t::get_device_list ()
Feb 20, 2020 02:02:28.426 [9540] INFO - [I] SAT2IP - discover_satip_servers(): no servers found
Feb 20, 2020 02:02:28.864 [2872] WARN - [E] enum_create(): Class not found, CreateClassEnumerator returned S_FALSE
Feb 20, 2020 02:02:28.864 [2872] INFO - [I] DeviceGetListEx_impl: pDL->Count:0
Feb 20, 2020 02:02:28.864 [9540] DEBUG - [I] file_tuner::get_stream_file. File C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private\devices\dvb\file\drv_file.ini does not exist
Feb 20, 2020 07:07:48.691 [11432] DEBUG - Unable to lock named mutex F8EEB26D-AB23-4061-8250-130AB5285A4A: 0x80
Feb 20, 2020 07:07:48.691 [11432] INFO - [I] device_manager_t::term
Feb 20, 2020 07:07:48.691 [11432] INFO - [I] device_manager_t::term. Stop all devices
Feb 20, 2020 07:07:48.691 [11432] INFO - [I] device_manager_t::term. Shut down all device auxes
Feb 20, 2020 07:07:48.691 [11432] INFO - [I] bda_aux_t::term
Feb 20, 2020 07:07:48.691 [11432] INFO - [I] web_server_t::stop. Web server is stopped
Feb 20, 2020 07:07:48.691 [11432] INFO - [I] broker_t::shutdown. Shutdown is completed.
Wondering if there a global mutex issue in general here?
Looks related to this: Plex Media Server Crash with Hardware Acceleration Enabled
But unclear why it started recently unless it was due to a Windows upgrade.
I have the exact same issue when trying to run XteVe. When browsing to the path C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private\devices\dvb\file\drv_file.ini does not exist there is no drv_file.ini file there.
Should there be??
