Plex crashing on synology DS918+
Server Version#: 1.19.3.2793
I was on version 1.15.xx. It started crashing occasionally, then it started crashing every time I started it. Upgraded to the version above. Same thing. Logs don’t seem to have any errors. It dies right after the tuner stuff loads and then the crash uploader runs.
I thought it was because I was low on space, so I added another drive. I have 9TB of free space now. Still crashed. Then I uninstalled and reinstalled Plex, and same thing… crashes when I try to start it.
Sent!
Logs (1).zip (1020.5 KB)
The plex server won’t run at all, so I cannot go into the settings. It crashes right away. Can I delete the Deadpool vid?
The Deadpool log was from May 14th, when things were still working (with occasional crashes). I just deleted Deadpool, but it still won’t start.
I grepped for errors, and these are the ones that come up for today:
fermat:Logs austad$ grep -i error * | grep "May 19"
grep: PMS Plugin Logs: Is a directory
Plex Crash Uploader.1.log:May 19, 2020 20:38:01.237 [0x7fa6acc98740] ERROR - Failed to upload crashdump 6077ab72-c4b5-29c9-0f049983-601753ed: 429
Plex Crash Uploader.2.log:May 19, 2020 20:36:30.371 [0x7fae0aa6c740] ERROR - Failed to upload crashdump 6077ab72-c4b5-29c9-0f049983-601753ed: 429
Plex Crash Uploader.log:May 19, 2020 20:38:06.959 [0x7fcb9590c740] ERROR - Failed to upload crashdump 6077ab72-c4b5-29c9-0f049983-601753ed: 429
Plex Crash Uploader.log:May 19, 2020 20:38:07.296 [0x7fcb9590c740] ERROR - Failed to upload crashdump 26eb25da-5cc3-7242-4430a58f-7e9d8416: 429
Plex Media Server.3.log:May 19, 2020 16:03:15.768 [0x7fd3625a1700] ERROR - LPE: unknown item 7942.
Plex Media Server.3.log:May 19, 2020 16:03:15.768 [0x7fd3625a1700] ERROR - Sync: failed to generate query for path library://dc5f6519-4d51-4766-9cb6-a874633f17f6/item/%2Flibrary%2Fmetadata%2F7942 in sync item 33368011
Plex Media Server.3.log:May 19, 2020 16:03:15.768 [0x7fd3625a1700] ERROR - Sync: empty sync set, unable to update status for sync list 31621734, sync item 33368011
Plex Media Server.5.log:May 19, 2020 15:58:46.576 [0x7f2923159700] ERROR - LPE: unknown item 7942.
Plex Media Server.5.log:May 19, 2020 15:58:46.576 [0x7f2923159700] ERROR - Sync: failed to generate query for path library://dc5f6519-4d51-4766-9cb6-a874633f17f6/item/%2Flibrary%2Fmetadata%2F7942 in sync item 33368011
Plex Media Server.5.log:May 19, 2020 15:58:46.576 [0x7f2923159700] ERROR - Sync: empty sync set, unable to update status for sync list 31621734, sync item 33368011
I don’t see any specific movie/tv files in here. Do I need to maybe delete the database and have Plex rebuild it all?
So I haven’t done this yet. Is there a way to edit the config to turn off sync, or a way to clear only the sync stuff from the database?
I don’t really want to lose my watched history in Plex.
